Crank no start 1996 LT4
Old Sep 12, 2020 | 06:24 PM
cdnbluez's Avatar
cdnbluez
Default Crank no start 1996 LT4
I have a 1996 LT4 and the car cranks but won’t start. I have no fuel pressure at the fuel rail when I crank the motor. I can’t hear the fuel pump priming.
I changed the fuel pump, and the fuel pump relay. The fuse is fine. I replaced the sending unit 2 years ago. Not sure what to try next. Any suggestions would be appreciated. Thanks.
Old Sep 12, 2020 | 06:28 PM
Nomake Wan's Avatar
Nomake Wan
Any codes from the CCM? Can you get the dash to go into diagnostic mode?
https://tech.corvettecentral.com/201...trouble-codes/
Unlike most cars where the fuel pump is driven by a main relay energized with the car, on the C4 the fuel system is energized by the CCM. If the CCM is malfunctioning or the wiring is bad, it can cause the fuel system to no longer energize. That's the first thing to check, just to be able to rule it out.
If you can rule that out, then it's time to bust out a multimeter and trace the wiring back from the fuel pump relay to see if there's power. And if not, see if you can trace to where the missing power comes from.
And as always, reminder that you can grab a FSM off of RockAuto for $20 and it's worth every single penny if you intend to keep your car and work on it yourself.
Old Sep 12, 2020 | 06:38 PM
cdnbluez's Avatar
cdnbluez
Thanks for the reply. Can you get an OBDII to go into ondash diagnostic mode?
I have fsm for the car. I guess I have to start reading.
Old Sep 12, 2020 | 10:23 PM
87redrocket's Avatar
87redrocket
it's basic but did you changed your fuel filter ?
Old Sep 13, 2020 | 12:03 AM
rhandle's Avatar
rhandle
It is probably the pump again! I have changed 4 in the last 6-7 yrs. ETHANOL kills these pumps especially if they sit a lot.
Old Sep 13, 2020 | 04:35 PM
cdnbluez's Avatar
cdnbluez
Today I checked the voltage at the tank and got close to 12. There is definitely power to the pump. So I pulled the 2 year old sending unit and put power to the new pump and it ran. I also put the old pump back onto the old sending unit and put power to it, and it ran as well. I decided to install the old rig because the pump was louder and easier to hear, and the car fired up and runs!
I don’t trust it, I hope its not intermittent. Lets see if I get stranded.
Old Sep 14, 2020 | 03:03 AM
Nomake Wan's Avatar
Nomake Wan
Yes, because the dash diagnostic is through the CCM, not the PCM. The PCM is the only component on the '96 that's actually OBDII. Every other computer in the car is still running the older ALDL comms. So it works exactly the same way as any other 90-95 C4.
Glad to hear you got it running, and here's hoping it works out!
Old Sep 18, 2020 | 11:12 AM
cdnbluez's Avatar
cdnbluez
Just a follow up. My car is running great, and somehow the level float is magically working again! Looks like the aftermarket sending unit I installed failed after 2 years. For those looking to replace theirs, I don't recommend using the Liland sending unit.
To Crank no start 1996 LT4
