Cold engine cut off
Old Dec 2, 2002 | 05:19 PM
dawgs55's Avatar
dawgs55
Cruising
Default Cold engine cut off
My "88" L98 w/ TPI will crank great but sometimes will cut off completely when it is cold. It will crank back then cut right back off. It will sometimes try to stay running while patting the accelerater. After a few minutes of this it will crank and run perfect. I never have a problem when the engine is warm. It mainly only happens when the outside temperature is 45 degrees and below. Anybody else had this problem? Just wanted to check here before I start trying to troubleshoot it myself. :confused:
Old Dec 4, 2002 | 12:49 AM
Tourney3p0's Avatar
Tourney3p0
Default Re: Cold engine cut off (dawgs55)
How does the idle look right before it shuts off?
Old Dec 4, 2002 | 01:20 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You might put a pressure gauge on the Schraeder valve to see if the fuel pump is running after it starts. If it is not, replace the oil pressure sender.
However, patting the accelerator makes me also suspect the IAC. You might try cleaning it and the throttle bores.
Old Dec 4, 2002 | 10:58 AM
dawgs55's Avatar
dawgs55
Cruising
Default Re: Cold engine cut off (Tourney3p0)
It never cuts off at a idle. Only when I am driving before it warms up.
To Cold engine cut off
