Running rough
Old Sep 16, 2020 | 11:10 AM
davetop's Avatar
davetop
6th Gear
Default Running rough
I hope somebody might give me some direction. I have a 1992 that has begun to run a little rough, and I am wondering how to fix it. Last winter (about a thousand miles ago ) it ran rough, and the check engine light came on, so I replaced the spark plugs and wires. Did not replace the optispark. The car ran better, but now it a little poochy again. No check engine light. This vette has barely been driven in the past four years ... maybe a tank of gas or so per year, so I suspect it might be some fuel turning to varnish. But I'm not sure how to diagnose something like that, if that is indeed the problem. What would a sage mechanic check first? Has anyone gone through something like this? Any help or suggestions appreciated.
Old Sep 16, 2020 | 02:18 PM
aklim's Avatar
aklim
How about checking the fuel pressure and spark quality to begin? Are your wires good?
Old Sep 16, 2020 | 02:27 PM
davetop's Avatar
davetop
6th Gear
Thanks Aklim, I put good wires on it not too long ago, so I believe they are good, as well as the plugs. Have not investigated the fuel pressure yet.
Old Sep 16, 2020 | 04:26 PM
87redrocket's Avatar
87redrocket
It could be so much things. Do you have any other symptoms ? Can you describe "rough" a little more ? Can you see the engine shaking ? Is it steady shaking or irregular ? Anything unusual that you can observe will help to narrow it down to the cause. Any loss of power ?
Start with the easy things
- Vaccum to the FPR (smell of gas) ?
- Vaccum leaks ? You can use the cigar trick or the MAF cleaner trick.
- Fire from the spark plugs ?
- Noid light on the injectors ? Resistance on the injectors ?
- Gas pressure (holding and while running) ?
- Good contact between the distributor rotor and cap ? (this is something that needs to be changed once in a while in these old vehicules.)
- Air filter ? Unplug it to see the difference ?
- etc ...
Old Sep 17, 2020 | 04:57 PM
davetop's Avatar
davetop
6th Gear
Thanks redrocket.
I have not driven it for a couple of weeks, so I just took the car out for ride, to get a feel for the way it's running. I did my normal twisty route, and then got it up to highway speed on the way home, about 20 miles total, and it ran fine. Did not seem to miss a lick.
One thing I did not mention: my wife put some regular gas in the car, a tank before the current one. After she did it, I put in some octane booster. Ran it down to about a quarter tank and refilled with premium. I never really noticed any issues, but now I wonder if there is a residual amount of regular gas that caused the problem a couple of weeks ago.
I need to be better about driving it regularly and keeping fresh gas in it. I'm going to keep your list of ideas in case it starts acting up again.
thanks again
Old Sep 17, 2020 | 08:28 PM
87redrocket
Nice to hear that it's back to normal. These cars have a knock sensor so it should work with regular or supreme.
Old Sep 17, 2020 | 10:53 PM
aklim's Avatar
aklim
Originally Posted by davetop
Thanks redrocket.
thanks again
What makes you think that you can notice anything unless it is severe? The knock sensor will retard timing when it hears knock before you can hear it and your butt isn't that sensitive that it can pick up loss of power unless it is severe. If you want to notice anything, you need a scanner to see what the ECM is doing and forget about what the butt dyno says.
Old Sep 17, 2020 | 11:34 PM
87redrocket
Here you go. i am not an expert....
Old Sep 18, 2020 | 10:50 AM
InfomanSS's Avatar
InfomanSS
When that check engine light comes on, get a scanner on it and research the code returned. Don't just throw parts at it. :-) Glad it is running better.
To Running rough
