Disconnecting battery and affecting computer.
Old Dec 2, 2002 | 06:30 PM
blk90rdstr's Avatar
blk90rdstr
Default Disconnecting battery and affecting computer.
What happens to the computer if you disconnect battery for a long time like 2- 3 months. I thought it needed to re-learn things like idle and WOT tuning etc. Is is true or just myth. I want to know if i should trickle charge my battery over winter or pull the cables and charge it in spring. Are there real temporary drivability issues after diconnecting power? Whats best for car? :confused:
Old Dec 2, 2002 | 06:50 PM
blu85's Avatar
blu85
Default Re: Disconnecting battery and affecting computer. (blk90rdstr)
I disconnect mine from Dec. to May and I've never had a problem in 5 years. When I start it in the spring it starts and runs like it had been run the day before.
Old Dec 2, 2002 | 06:58 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I've always understood that keeping a trickle charge on prolonged battery life. Plus, if you are able, you might want to start it once a month and let it run for a while...turn the AC on! Run it through the gears ( auto tranny) with foot on brake. Seals, etc. dry out from lack of use/lubrication. AC compressors are especially vulnerable, or so I have been brought up to believe :D
:seeya
Old Dec 3, 2002 | 06:46 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Left my battery disconnected on an '84....with no problems.....but don't know about the later vette's.....It should reset....but then again?????????
:eek: :eek: :eek: :eek: :eek:
Old Dec 3, 2002 | 08:38 PM
1MoorTym's Avatar
1MoorTym
I don't know if the 'learned' settings are saved in a non-volatile (does not need constant power) form or not. If these settings require constant power (I think this to be the case), it doesn't matter if the time disconnected is 5 minutes or five months. It will re-learn them.
With the battery its better to leave it on a trickle charge rather than charge it once in the spring.
To Disconnecting battery and affecting computer.
