Misfire
Old Sep 25, 2020 | 09:17 AM
chevss's Avatar
chevss
1st Gear
Default Misfire
Have a 86 that has a misfire on cylinder 5.6,7 .replaced plugs wires injectors.compression is good . Fuel pressure is good , furs are good ! Any help would appreciated as I don’t know where to go now
Old Sep 25, 2020 | 09:33 AM
InfomanSS's Avatar
InfomanSS
What is "furs are good"?
Any codes from the system?
Old Sep 26, 2020 | 09:45 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Compare appearance of those plugs with that of plugs from other cylinders. If they look like running rich you could try having the injectors pressure cleaned.
Old Sep 27, 2020 | 09:58 AM
jazfe's Avatar
jazfe
Pull the distributor cap and have look. Those cylinders fire one after the other so could be something in there messing with your timing.
Old Sep 28, 2020 | 02:49 AM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
Did you have these symptoms before the plug wires were changed? As trivial as this may sound, is the plug wires in the correct order?
To Misfire
