Big G
Old Sep 29, 2020 | 06:38 PM
madatcorvette's Avatar
madatcorvette
1st Gear
Default Big G
Hi my name is Glenn, I'm a was a proud owner of a 87 corvette till
Hi my name is Glenn proud owner of a 87 C4, till my vats system crapped out on me and my chip fell out of my key, can't find the ohm # number for bypass any answers please
i
Old Sep 29, 2020 | 07:48 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum, Glen, and congratulations on your C4!
Lots of great members and helpful info in the C4 sections at https://www.corvetteforum.com/forums...-1984-1996-19/.
I would encourage you to post your question in the Tech section there.
In the meantime, here are a few possible helps:
Best wishes for an easy and inexpensive fix!
Old Sep 29, 2020 | 08:00 PM
Moved over to C4 Tech. Good luck with a solution to your car's problem.
Old Oct 1, 2020 | 06:25 PM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
If your intention is to bypass the VATS, the kits come with all the available resistors and you can try it 1 at a time until it works. There's also PROM tuning that can remove it.
Ebay listing
Old Oct 2, 2020 | 08:32 AM
KyleF's Avatar
KyleF
Ebay listing
This is the proper way to do it. However, if you are getting a PROM let me make this suggestion:
You may not wish to do you own tuning, but having a good data logging set up will help down the line with any issues you may have. So, I would suggest getting a ALDL to USB cable - Available at MOATES.NET, Download Tuner Pro RT, and get the files to start scanning your car. There are a few guys, but one I know best, who can do a tune based off data logs to improve the overall performance. He would send you a basic tune with VATS disabled on a chip. Then you would send him scans and do a chip exchange. In the end you will be set up with no VATS, a better tune/running car, and have a way to read and log data.
To Big G
