Pilot bushing recommendation
Old Oct 3, 2020 | 11:56 AM
9T3VETTE's Avatar
9T3VETTE
Default Pilot bushing recommendation
From what I’ve read it’s preferred to go with a bushing rather than a needle bearing. Is there a specific bushing brand/design preferred?
Just realized my new motor does not have one and will need to order.
Old Oct 3, 2020 | 12:38 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
IDK why people prefer the bushing...My preference is the needle bearing.
For bronze, I doubt any one brand is better than another. Get one from a local auto parts store and you should be fine.
Old Oct 3, 2020 | 01:25 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
my 2007 z06 came from the factory with a roller bushing and it was a biotch to get out. a real heavy duty unit.
Old Oct 3, 2020 | 01:50 PM
9T3VETTE's Avatar
9T3VETTE
From what I can tell my factory piece is a bushing? I’ll snap a picture and post later
Old Oct 3, 2020 | 03:56 PM
9T3VETTE's Avatar
9T3VETTE
My FSM calls it out as a bearing, however the OEM crank bearing looks to be a bronze bushing. Picture below:
Old Oct 3, 2020 | 06:49 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That is a bronze bushing, for sure.
Use which ever suits your fancy.
Old Oct 3, 2020 | 10:31 PM
MatthewMiller's Avatar
MatthewMiller
That is the GM fluted bronze bushing, which I believe they call "oilite" because it's self-lubricating. The part # is CT1088. This is what seems to have come stock in the LT1 and LT4. I'm no expert, but this is what was recommended to me by Jim Jandik of PowerTorque Solutions, one of two ZF/clutch gurus. I know the previous owner of my car had installed a roller bearing instead, and it came out in pieces. That's just one case rather than a body of proof, of course. But your bearing still looks great so I see no reason to go with anything different.
Old Oct 3, 2020 | 11:11 PM
jv9999's Avatar
jv9999
If you do go with a bushing make sure it's a good one. A magnet should not stick to it. A lot of cheap bearings have a high iron content that will wear your input shaft.
Old Oct 4, 2020 | 09:24 AM
jmgtp's Avatar
jmgtp
I went with this one, looked just like the OEM one that came out at nearly 120k
Amazon Amazon
Old Oct 4, 2020 | 09:51 AM
9T3VETTE's Avatar
9T3VETTE
https://www.amazon.com/dp/B000C9SID0..._YXCEFbRRMZKYK
Just ordered it, thanks. My local parts store said they could not get the Delco version.
for install, tap it in with a matching socket size diameter?
Old Oct 4, 2020 | 10:23 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yep.
Old Oct 4, 2020 | 02:57 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
I like to put it in the freezer over night. Makes it go in a bit easier.
To Pilot bushing recommendation
