Smog pump delete?
Old Dec 3, 2002 | 09:39 PM
apollo30346's Avatar
apollo30346
Default Smog pump delete?
Is there a way to do this without spending the $170.00 on that elim bracket....I want to clean up the engine bay some...I have already gutted it and removed all the tubing... But, I want to delete it and get it out of there....I have tried to think of a way, but have drawn a blank.... Isn't there a AC elim bracket that can be purchased from the dealer for little money and maybe change it someway to work for this...Keep in mind this is on my 88 model...If anyone has done this, please let me know what I can do or any help....The $170.00 for the bracket seems a little bit much for what it is....
Please chime in with any thoughts....
Old Dec 3, 2002 | 09:55 PM
ZAD54's Avatar
ZAD54
Default Re: Smog pump delete? (apollo30346)
Hmmmm, your car looks vaguely familiar for some reason. I spent the cash for my elim bracket, but a friend made his own. :cheers:
Old Dec 4, 2002 | 06:23 PM
apollo30346
Default Re: Smog pump delete? (ZAD54)
Does doesnt it.... :D ... I wish I had the access to a machine shop now, but I don't..... I guess I will keep trying..... I wish I had the Automatic like you.....If you could get some info on what he did and how he made it, that would be great....
Old Dec 4, 2002 | 06:39 PM
CptMorgan's Avatar
CptMorgan
Mmm... Looks like my car too...
I bought the bracket throught the Forum Mall (save %10) and have been very happy with it. But it was alot more money than I wanted to spend. Since then there have been a few for sale in the Buy/Sell C4 section for much cheaper.
Old Dec 4, 2002 | 06:45 PM
MrNuke's Avatar
MrNuke
I have access to a machine shop.. What are the specs? I am looking to do one for myself aswell.. :D
Old Dec 4, 2002 | 09:48 PM
ZAD54's Avatar
ZAD54
Well I really can't say that he made a copy of mine because I'm sure Breathless Performance would get alittle made about something called Copyright Infringement. He still hasn't put his on, but it should work. And if for some reason BP reads this, it isn't an exact copy. He changed some things he didn't like. :cheers:
Old Dec 4, 2002 | 10:37 PM
MrNuke's Avatar
MrNuke
Actually since I'm installing a vortech soon, that'll probably take care of the air pump as it is.. :D
Old Dec 5, 2002 | 01:40 AM
ol,RJ's Avatar
ol,RJ
the AC eliminator bracket you spoke of should be available thru GM. It was used on TPI Camaro's that didn't have AC. (sorry I don't know the part #)
Old Dec 5, 2002 | 07:12 PM
apollo30346
Default Re: Smog pump delete? (ol,RJ)
I wonder what year I would have to ask for....I wonder if I could get a picture of one from somewhere.....That would help me to figure out if I could make it work....Hard to do this in my garage without having access to a shop....Keep the ideas and help coming.....
Old Dec 7, 2002 | 09:54 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
In Southern CA.....CAN'T DO...good luck to you....go for it...I would if I could get away with it...
:eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:
Old Dec 8, 2002 | 06:04 PM
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
CI 4-6-8 & 10 Veteran
St. Jude Contributor
:sad: oops.
I need to read the post better before I reply.... :cry
[Modified by Fozzy_Bear, 6:08 PM 12/8/2002]
Old Dec 9, 2002 | 06:16 PM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
Default Re: Smog pump delete? (Fozzy_Bear)
I did the Breathless elim for the air pump as well. But I've been looking for an A/C replacement and can't find one. Ol'RJ a few posts ago mentioned an A/C replacement for the camaro. I was told about that as well. Was at Chevy/Vettefest in Chicago a few weeks ago (My car was shown) and I walked around for two days talking to Perf shops, resto guys, other car owners like mine, and nothing. One said that the camaro part won't fit for some reason, different bolt pattern than an L98 or something? Anyway, if you find an A/C replacement pulley system, let me know! Thanks. :cheers:
Old Dec 9, 2002 | 06:44 PM
VetteRacer282's Avatar
VetteRacer282
Default Re: Smog pump delete? (MJT383NO2)
I am in the process of making a so called A/C eliminator bracket. Going to cost about $10 probably. Peice of scrap aluminum, some steel rods. Putting the tensioner pully on it for proper belt routing
I will be posting pictures of it when I am done. I will probably redo it in steel once I get it made right, then get it welded.
As for the SMOG Pump. Has anyone tried using a Heim Joint to replace the smog pump bracket? I dont think you NEED that pulley there. My car is different then all yours. I have no A/C, No Smog pump, an electric waterpump. So the belt routing isnt quite the same. But I will be using a heim join setup for the second alternator mount.
Might be worth someone looking into...
Matt
Old Dec 9, 2002 | 06:45 PM
VetteRacer282
Default Re: Smog pump delete? (VetteRacer282)
Oh yeah... as for the Camaro eliminator part. I THINK it wont fit because of the spacing. The distance from block to pulley is different. Atleast thats what I think I found out while looking for this myself.
Matt
Old Dec 9, 2002 | 07:13 PM
UB2 SLOW's Avatar
UB2 SLOW
From: I could tell but then I would have to kill you
I have a question? What kind of benifits would you get doing this mod? I might do it myself if its worth it.
Old Dec 10, 2002 | 02:11 AM
VetteRacer282
Default Re: Smog pump delete? (UB2 SLOW)
UB2 SLOW: For you, nothing!
You have an electronic smog pump, it causes no harm (runs for the first 45 seconds the car is cold started, I beleive). On the L98 cars its a belt driven pump, looks ugly, and supposidly eats up power. (I removed mine for cosmetics).
As for the AC eliminator. Again, no gain, if its not engaged its not taking any power away (maybe .0001% or something very minor). Again, removed mine for cosmetic, and use of car...
Matt
Old Dec 10, 2002 | 11:08 AM
Matt383's Avatar
Matt383
A/c elim for me is two things. Cosmetics and weight. I think the whole A/C system weighs about 70 lbs. or so with the condensor, plumbing, motor assembly, etc. Plus the drag elimination no matter how small is OK w/ me.
The air pump weighs 20 lbs or so as well. So I would call the removal of 70 lbs. an improvement. So I'm still looking for an A/C delete option that works as well or better than the air pump delete.
Matt :chevy
To Smog pump delete?
Old Dec 10, 2002 | 11:22 AM
ZylaRace's Avatar
ZylaRace
AC compressor replacement wheel: P#10055890 ~$45
Old Dec 10, 2002 | 11:36 AM
Matt383's Avatar
Matt383
Default Re: Smog pump delete? (ZylaRace)
ZylaRace,
Thanks! Is this a vette part? Have you used it on an L98? The reason I am asking is that someone suugested a camaro part that I've heard will not work.
If this works, this will be the best info I have recieved off this forum so far.
I've been looking at vette shows, calling catalogs, talking to perf shops, etc.
The only answer I got before you was to custom fab. Thanks again.
Matt :cheers:
Old Dec 10, 2002 | 12:07 PM
VetteRacer282
http://mywebpages.comcast.net/tstrel...enginemod.html
I beleive the top picture has the part installed.
Again, if its as I am told, its not spaced away from the engine properly for a Corvette, but worth looking into.
Also, Matt. I sent an email to you...
Matt
