Doesn't do anything
Old Oct 11, 2020 | 03:30 PM
dickard's Avatar
dickard
2nd Gear
Default Doesn't do anything
More problems with my '94! It revved on start up try for about a second and then everything went dead. Just had several leaks fixed, new rack/pinion put on, a brake sensor put in and the cruise control fixed. Any idea on what might of happened now? Battery shows charged. There are no interior lights, Nothing happens when I turn the key to on. What fueses might I check first to see if there is any easy fix? Thanks
Old Oct 11, 2020 | 04:11 PM
dickard's Avatar
dickard
2nd Gear
Unhooked the negative battery terminal, waited for about two minutes, reconnected and it reset. Obviously not much of a mechanic, but a pretty happy camper right on!
