I have a code :(
Old Dec 3, 2002 | 11:08 PM
GhostOfFreedom's Avatar
GhostOfFreedom
Default I have a code :(
well i was driving my car about 2 nights ago and i got a brake light on the dash i was going up hill not a big hill but i was going up doing about 55 so anyways it says on then it goes off and i get service abs and asr so i turned off the car (after i stoped somewhere) then i started her back up and everthing was fine well to night i wanted to pull the codes and i have a h83 in number 9. i hope u guys can help me.
Ps i am sorry about grammer i was just typing sorry
[Modified by GhostOfFreedom, 4:38 PM 12/4/2002]
[Modified by GhostOfFreedom, 4:41 PM 12/4/2002]
Old Dec 4, 2002 | 09:58 AM
GhostOfFreedom
does anyone know what a code 83 is.
Old Dec 4, 2002 | 10:20 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: I have a code :( (GhostOfFreedom)
The code 83 is TCC PWM solenoid circuit failure. HTH.
Old Dec 4, 2002 | 11:17 AM
GhostOfFreedom
So What does that mean the car seems fine everythings working???
Thank You for helping :D
Old Dec 23, 2004 | 08:21 PM
jdbxyz's Avatar
jdbxyz
I'm not sure what year you have, but for 92-96, Code 83 in module 9 is "Brake Fluid Level Low". Top off with fluid and you should be OK. Below is the web address to the corvette action center that list all codes for brakes.
http://corvetteactioncenter.com/kb/q...n.php?qstId=95
Hope this info helps.
Old Dec 23, 2004 | 09:09 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
The "H" is for history. This means it could be an old code that was never cleared after a repair. Clear it by disconnecting the neg post of battery and waiting about a minute then reconnecting. If it's still a problem it will re-throw the code. If not you'll be in good shape.
To I have a code :(
