Coating on head bolts before reinstall ?
Old Dec 4, 2002 | 01:46 AM
keekster's Avatar
keekster
Default Coating on head bolts before reinstall ?
What do people coat there head bolts with before reinstalling them ?
Old Dec 4, 2002 | 01:50 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Coating on head bolts before reinstall ? (keekster)
When you say re-install do you mean install new ones or re-use your old ones? You're really not supposed to re-use head bolts anyway because they stretch when you torque them the first time.
That being said I used ARP bolts with the ARP thread sealer / assembly lube, that stuff does wonders, it lowers the friction so much that the required torque spec is like 20 pounds lower than if you had just used oil alone. So far so good I haven't had one single problem. I also used ARP assembly lube on my header bolts. It allowed me to tighten them much easier and none of them have backed out at all.
Old Dec 4, 2002 | 01:58 AM
sunrise.cm's Avatar
sunrise.cm
I bought new bolts from GM and used "Permatex High Temperature Thread Sealant" with excellent results. Comes in a white tube. Good stuff IMO. I cleaned and chased theads in block.
Old Dec 4, 2002 | 02:24 AM
Hamert's Avatar
Hamert
GM sells the stuff to use, it comes in a tube. I think it's called teflon thread sealant
Old Dec 4, 2002 | 02:29 AM
keekster's Avatar
keekster
is it a real bad idea to reuse your old bolts ?
Old Dec 4, 2002 | 03:21 AM
sunrise.cm's Avatar
sunrise.cm
Nope. Not a good idea.
Old Dec 4, 2002 | 02:23 PM
fullboogie
Default Re: Coating on head bolts before reinstall ? (sunrise.cm)
To get proper torque readings, you should use whatever the manufacturer suggests using. Some require engine oil, some require cam lube, others a teflon-based sealant, etc.
ARP suggests using Childs & Albert assembly lube.
Old Dec 4, 2002 | 05:01 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Do a web search of "Torque to Yield" (or TTY for short) head bolts.
When I did, I found a bunch of information. The short story, they should be replaced. I bought new bolts from GM but found it difficult to use the Torque Angle Meter. Next time, I would use standard ARP head bolts that are not TTY. They are only $45/set.
As a side note, I could not find in the Helms shop manual any instructions whether or not they should be replaced.
Scoggin-Dickey sells a complete set for $27.
[Modified by Mez, 4:02 PM 12/4/2002]
To Coating on head bolts before reinstall ?
