85 odometer not working
Old Oct 15, 2020 | 06:35 PM
banditt1979's Avatar
banditt1979
Default 85 odometer not working
I have an 85 Z51 with an LQ9/4L60E swap being controlled by the Holley Terminator X Max system. Last week I was able to get the speedometer working with the assistance of a Dakota Digital convertor box. But the odometer is not working. The speedo and trip odometer work fine and logging miles/mph correctly. Does anyone know of a method of testing the odometer motor to see if it is functioning? Is it a matter of applying low voltage to the motor to see if it spins? I've searched on here and at batee's website and couldn't find anything. Thanks in advance for any tips!
Old Oct 18, 2020 | 10:33 AM
banditt1979
Surely someone has some info?
Old Oct 22, 2020 | 09:50 PM
banditt1979
Ok well I went ahead and pulled the odometer and applied 9 volts from a 9 volt battery. Nothing. So i dug deeper and pulled the front of the motor apart. Theres several small gears inside. The motor felt stuck and wasnt moving at all. So I turned it with a small pair of pliars and got it unstuck. Now the motor moves a little but still doesnt spin. I dont know if the cluster sends it a different type of signal or what. But i put it back together and will try it out tomorrow.
Old Oct 22, 2020 | 09:53 PM
banditt1979
Old Oct 22, 2020 | 11:12 PM
jv9999's Avatar
jv9999
The cluster sends it a pulse every 1/10 of a mile.
Old Oct 23, 2020 | 08:35 PM
banditt1979
So taking the electric motor apart and getting it to spin solved the problem. I used my phone with the Dakota Digital app to send a pulse signal to the cluster and the odometer rotated and advanced several tenths as I resent the test pulse. Problem solved! Hope this helps anyone with the odometer issue. Seems like the motor gets stuck with 35 years of grease drying up on it.
Old May 2, 2025 | 03:11 PM
gh0stmach1ne's Avatar
gh0stmach1ne
I tried doing the same thing to my motor but whenever I applied voltage it always spun back to the same spot regardless of which way I set the polarity. I'm assuming there's something amiss deeper inside the motor itself so I guess I'll just be ordering another one ¯\_(ツ)_/¯
Old May 2, 2025 | 10:30 PM
LiveWire1's Avatar
LiveWire1
Good story. Thanks for the advice. I have a similar problem and I'm going there after this cruise season.
Old May 8, 2025 | 12:51 PM
gh0stmach1ne
So it turns out this is just how stepper motors work and it actually works fine! This thread was super helpful! Thanks!
Old Sep 6, 2025 | 05:34 PM
RA92625's Avatar
RA92625
1st Gear
This thread is the best, had the same problem, opened up the motor, wiggled the main axle a bit, but it still got stuck, sprayed it with some electronics anti oxide. then it started working. And thanx to the picture earlier in the thread I managed to put it back together.
Many thanx for the great info.
To 85 odometer not working
