86 iron head flow rates.
Old Oct 17, 2020 | 08:00 PM
matt sallo's Avatar
matt sallo
5th Gear
Default 86 iron head flow rates.
New member question: My iron head,,, has the raised #'s 482824 and I215 on it.
How may I find cfm rates with this info?
Rude.
Forgot the thanks.
Thanks!
Old Oct 17, 2020 | 09:47 PM
84 4+3's Avatar
84 4+3
Rude.
Forgot the thanks.
Thanks!
I believe you have 462624 heads. Should be easier to look up.
They don't flow good.
Old Oct 18, 2020 | 12:10 AM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
http://users.erols.com/srweiss/tablehdc.htm#Chevy
Old Oct 18, 2020 | 12:34 AM
matt sallo's Avatar
matt sallo
5th Gear
Default They don't flow (so i'm told).
Thanks 84. If you say the #'s are 4626 that's good enough for me.
I'm so new enough at this that being "easier to look up" is still difficult because of not knowing
where to look up.
I want to put in Dart's 180cc pro platinum heads which are better of course.
I'm wanting to know how much better.
Thanks again, and where do I look?
M
Just noticed stew86's reply.
Thanks.
Last edited by matt sallo; Oct 18, 2020 at 12:39 AM. Reason: just noticed stew86's reply
Old Oct 18, 2020 | 07:45 AM
84 4+3's Avatar
84 4+3
where to look up.
M
Thanks.
I was in a limited coverage area last night. Id normally look it up myself and post a link. But I know they're weak. Weak casting and flow being honest.
Old Oct 18, 2020 | 11:48 AM
matt sallo's Avatar
matt sallo
5th Gear
Thanks 84. Your correction and Stew86's treasure map lead me right to the answer.
L83 462624: Port volume 158/ chamber 76/ .500 lift 196/140
Dart Platinum: 180/ 64/72 257/172
Undecided on chamber size. Street motor build. Comp cam #252FI HR13/ lift .550-.546.
Stock plenum, TPIS headers, Pistons, yes pistons she will have pistons. What kind?
Flat? Small dome? The motor builder will know.
From my position on the learning curve, this looks like fun.
Thank You!
Old Oct 18, 2020 | 12:08 PM
84 4+3's Avatar
84 4+3
Thank You!
With a small cam like that I'd go with the 72s. Don't have to worry about fuel octane then.
Old Oct 18, 2020 | 03:24 PM
stew86MCSS396
What I found interesting with the link of cylinder head flow, the owner of the site does say he compiled all the data from all sorts of sources. i.e. internet, magazines, publications etc. With that said the flow numbers as listed for the 462624 heads came from CF member Joby.
Old Oct 18, 2020 | 07:09 PM
matt sallo's Avatar
matt sallo
5th Gear
Thank you gentlemen.
I see the motor man in the morning.
If November 3 goes well we will launch.
If gas goes to $65/gallon with AOC as secretary of energy,
never mind (as Roseann Roseannadanna might say).
M.
To 86 iron head flow rates.
