Roller rockers
Old Oct 19, 2020 | 10:17 AM
Cam813's Avatar
Cam813
Default Roller rockers
What do people with 88-91 vettes do about roller rockers and tall valve covers? I pulled the ac on mine because of clearance issues with the ac compressor. I suppose I could cut and weld the valve cover (well pay someone to do it), but alternative solution, could one run 85-87 ac setup since it's mounted in front of the head as opposed to on the side? Anyone out there done this?
Old Oct 19, 2020 | 11:58 AM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
what i did on my 89 was to relieve (grind) the a/c compressor bracket to allow the valve cover to come up and away from the a/c. if you look at the valve cover from the top and pull up on it, you can see where the bracket needs to be ground. use a marker to make a profile of what material needs to be removed then it becomes grind and fit, grind and fit.
Old Oct 19, 2020 | 12:05 PM
Cam813's Avatar
Cam813
I notched the bracket and have clearance for that but the actual compressor itself is what the clearance issue is for me. Can you send me a picture or two of your setup?
Old Oct 19, 2020 | 12:10 PM
Sleazy Rider
i have since sold that car, had it from 1990-2020. i may still have the bracket but it will take some time to locate it.
Old Oct 19, 2020 | 12:14 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I ran roller rockers under 'Vette valve covers by simply breaking the oil drip tabs off the insides of the valve covers. Worked fine, for me.
Old Oct 19, 2020 | 12:24 PM
Cam813's Avatar
Cam813
I'll look into that!! Thanks for the tip. I'm definitely going to feel like a bozo for pulling the ac if I could have just modified the stock covers! Live and learn.
Old Oct 19, 2020 | 12:48 PM
Sleazy Rider
i was running roller rockers and a girdle. wasn't going to fit under stock covers and had to go to a tall cover which is what i did for the clearance and r&r of the covers.
Old Oct 19, 2020 | 01:06 PM
Cam813's Avatar
Cam813
Sleazy, were you able to retain stock ac compressor? What year is yours?
Old Oct 19, 2020 | 02:44 PM
Sleazy Rider
i was able to retain the factory compressor and this was on my 89 coupe.
Old Oct 19, 2020 | 04:29 PM
RWDsmoke's Avatar
RWDsmoke
I would never go back to the early r4 compressor, the Denso is much smother and quieter. For tall valve covers I had to grind just a little on the bracket where it was hitting the corner of the valve cover and used 3/8" spacers to move the compressor out away from the cover. I did use longer bolts, I didn't have the original bolts so I don't know if they would have worked.
Old Oct 19, 2020 | 09:59 PM
TBSS/85vette's Avatar
TBSS/85vette
I have full stainless roller rockers under the stock valve covers on my 1985. I just used a Dremel to cut off the drip tabs and then ground them flat.
Old Oct 19, 2020 | 10:20 PM
aklim's Avatar
aklim
Me too
Old Oct 20, 2020 | 03:43 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When I put ProMagnum 1.6:1s into my prior '88 I did the same cover treatment to get ample clearance with OEM covers, no problems.
Old Oct 20, 2020 | 06:42 AM
Cam813's Avatar
Cam813
Thanks for the input everyone! I'm going to track down a set of the early valve covers. The heads I swapped on are perimeter bolt only.
Old Oct 20, 2020 | 11:13 AM
Mjet67's Avatar
Mjet67
Sleazy Rider...I bought an AC bracket from you last year..
for my 89 that was relieved, might be the one you are thinking of.
Old Oct 20, 2020 | 12:32 PM
Sleazy Rider
if you bought a relieved a/c bracket from me, to the op, then i do not have that bracket anymore.
To Roller rockers
