need VATS Module need help
Old Oct 19, 2020 | 07:03 PM
rphillips97's Avatar
rphillips97
Default need VATS Module need help
The VATS module had gone bad in my 86 C-4. I have found several used ones but I can't find how to tell what key resistor they take? Is there any way to tell what key they take by the numbers on the module? Mu module is #16039969 8546 and takes a #6 Key (1470 ohm). Does anyone have a module and know what key it uses? Any help is certainty appreciated.
Russell
Old Oct 21, 2020 | 07:46 PM
RalfKramden's Avatar
RalfKramden
As a suggestion, you could either get your ECM flashed which would remove VATS or buy and install a VATS bypass. I installed a bypass (it removes the VATS module completely) and haven't had a problem since.
This is the one I installed (
Amazon Amazon
Old Oct 21, 2020 | 11:23 PM
WVZR-1's Avatar
WVZR-1
Russell
Your 16039969 I'd expect to be same/similar (most likely) to what's discussed in this thread.
ID the resistor @W to confirm.
https://www.corvetteforum.com/forums...schematic.html
Old Oct 24, 2020 | 07:18 PM
rphillips97
Thanks for the help. The module is just what I was looking for. I use Amazon every week but I totally overlooked them on this issue. Thanks again.
Old Oct 24, 2020 | 07:19 PM
rphillips97
Thanks so much for your help. I see I'm not the only one to have this issue.
To need VATS Module need help
