Stock TPI base.
Old Dec 4, 2002 | 11:59 AM
devilfish's Avatar
devilfish
Default Stock TPI base.
Can you port the stock tpi base? Is the tpis big mouth just a stock ported tpi base? Or is it more to this then just porting.
Regards
Old Dec 4, 2002 | 12:26 PM
dgoodhue's Avatar
dgoodhue
Default Re: Stock TPI base. (devilfish)
TPIS Bigmouth is a different casting, not a ported stock base. You can get a ported stock base to flow as much as an untouch TPIS Big Mouth, but it will probably cost just as much. A ported Big Mouth will outflow a port stock base.
Old Dec 4, 2002 | 12:31 PM
vader86's Avatar
vader86
the Bigmouth has much bigger ports and allows some more porting
its based on the TPI manifold, but is a totally different casting
and it flows alot better than the stock ported
Old Dec 4, 2002 | 12:34 PM
BBA's Avatar
BBA
About the best you can do for a stock base in siameese the adjacent runners.
The big mouth is totally different, and the rear runners interfere with the distributor mounting, so it has to be machined for the stock distributor to still fit, or you have to use a small base distributor.
Either way, the big mouth is totally different in physical size.
Old Dec 4, 2002 | 02:34 PM
dgoodhue's Avatar
dgoodhue
Default Re: Stock TPI base. (vader86)
Someone fully ported a stock base and was able get to slightly outflowed an aftermarket TPI base on an air flow bench. I still would go with an aftermarket base though.
Old Dec 4, 2002 | 03:44 PM
vader86's Avatar
vader86
Default Re: Stock TPI base. (dgoodhue)
Do you know which base they tested it against? the Accel, TPiS, edelbrock?
Old Dec 4, 2002 | 03:53 PM
LD85's Avatar
LD85
http://iroc.fbody.com/intake.html
Here is some info that may or not or may not be accurate and is justa link I found one day, I swear! , (see the THINK BEFORE YOU POST THREAD)
Old Dec 4, 2002 | 04:20 PM
dgoodhue's Avatar
dgoodhue
I honestly don't remember, but I want to say it was an edlebrock. I am pretty sure it was on the thirdgen, I can't find the exact thread though.
I did find this though, which seems to have a good porting advise.
<A HREF="http://www.thirdgen.org/techbb2/showthread.php?s=&threadid=43923&highlig ht=stock+ported+intake+flow%2A" TARGET="_blank">http://www.thirdgen.org/techbb2/showthread.php?s=&threadid=43923&highlig ht=stock+ported+intake+flow%2A</a>
about half way down
Where the ported intake flow 255cfm vs stock 220cfm, which is close to teh number of
The intake numbers of 222cfm stock & 251cfm Accell
Old Dec 4, 2002 | 05:44 PM
MrNuke's Avatar
MrNuke
If you port the lower intake be careful..
if you siamese the runners on the lowe rintake, factor in, that goign too deep
will totally mess your engine's charctersitics up.
Example : Siamese 3" deep and you might gain about 1K rpm higher breathing, but since your cam is designed for UNDEE that, you just sacrificed who knows how much power on the low end. It ahs to be a nicely thouht out balance. I was gonan do this on my car, as I have the whole intake, ported and siamesed with SLP runners, but I woudl have only gone 1" deep to add about 300rpms or so more breathing and not mess with the car's cam. (I don't want to mess with the engine's original design, see how fast I can get her)..
It is a pita to do though..Not looking forward to it..
I was thinking of offering this service to corvette owners, but doubt I could
get enough business to make it worthwhile..
Old Dec 4, 2002 | 06:20 PM
CarAteMyMoney's Avatar
CarAteMyMoney
Default Re: Stock TPI base. (MrNuke)
This is probably a naive question, but isn't it only necessary to break the stock 225 cfm per port if your cylinder head can take that much?
I have an intake off my old IROC I was thinking of porting but I'm not totally sure how i'm going to go about it yet, does anyone have pictures of ported stock manifolds? :confused:
Old Dec 5, 2002 | 10:20 PM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: Stock TPI base. (CarAteMyMoney)
Sorry, I really don't intend to hijack this thread (I know it is against the rules) but I have to say I love your username, CarAteMyMoney. :D
Old Dec 6, 2002 | 12:59 AM
BBA's Avatar
BBA
It is not the 225 cfm flow rate that is the problem here with the stock TPI...it is the air flow resonance due to the geometry of the runners that impedes airflow at high rpms.
Ironically, it is the same effect that increases low RPM power by aiding air flow at 1000-2000RPM, allowing greater than 100% Volumetric efficiency in the cylinders without supercharging.
By cutting a channel between the adjacent runners, you alter the resonance characteristics of the manifold ( or the "TUNE" of the "Tuned Port" ). This is what gets you the resulting increase in high RPM air flow, not just making the port bigger. Technically, I guess you could say it's decreasing the impedance to high RPM air flow...instead of increasing the airflow directly.
[Modified by BBA, 1:00 AM 12/6/2002]
Old Dec 6, 2002 | 01:13 AM
gtsyellow's Avatar
gtsyellow
Default Re: Stock TPI base. (BBA)
*stock flow at .500 is actually 193cfm, the 225 cfm you stated & i'm taking a ballpark guess here came from my old post on 113 casting flow?* if it didn't i appologize but it's funny my home ported 113 castings flow 225cfm@.500 lift, it took some work to get that however. manley race flo necked valves, a 3 angle job, some bowl porting and short turn radius work along with a small increase in runner volume & removing casting flaws. this is a pretty good post with some pretty decent advice. if you can buy a accel or TPIS base i highly suggest you do so, the casting is larger and SAVES YOU SO MUCH TIME trying to port a gm one, and i mean a LOT of time, like over 10hrs on a port bench to really cut a stock one open and finish it up. it's nuts really espessialy when accel bases are $389 and TPIS is what? like 475? they are basically the same by the way so i'd get the accel one. it also allows the siamesed runner or super ram top to go on at a later date without worrying if the base flows enough.
Old Dec 6, 2002 | 09:33 AM
TA's Avatar
TA
Is this the case with the other aftermarket bases as well (accel, edelbrock) or this this strictly a problem with the big mouth base? I'm planning on installing an aftermarket intake in the future and just want to be aware of any potential problems. Thanks
Old Dec 8, 2002 | 02:02 AM
The Dingo's Avatar
The Dingo
Default Re: Stock TPI base. (TA)
The only "mod" I had to do after installing my ACCEL base was bending the EGR electrical plug bracket that bolts to the rear of the thermostat housing upward to fit by hand. No other fit issues whatsoever.
Here are the pics I have on my homepage, both bases are as cast with no porting:
ACCEL base at top: http://temp.corvetteforum.net/c3/red..._sizes_sml.jpg
OEM at top, ACCEL at bottom: http://temp.corvetteforum.net/c3/red..._sizes_sml.jpg
I took measurements when I did the install and there is so much less material in the OEM base that you would have to port it to within an inch of it's life to reach the port size of the stock,unported ACCEL base.
[Modified by Red 90 L98 Coupe, 1:03 AM 12/8/2002]
To Stock TPI base.
