Shifting rpm range
Old Oct 22, 2020 | 04:42 PM
  #41
vette196's Avatar
vette196
Originally Posted by 383 First
Syngarage they are in Ringwood NJ
I thoght you were going to tell me about the place in garwood....they don't reply to calls or emails. I'll have to check this one out
Old Oct 22, 2020 | 04:55 PM
  #42
383 First's Avatar
383 First
Originally Posted by 84 4+3
You run island right?
Yes we do...
Old Oct 22, 2020 | 04:58 PM
  #43
383 First's Avatar
383 First
Originally Posted by 383vett
I've spent much time dialing in the governor of a 700r4. If you want to raise the shift points at wot, you can carefully grind some some meat off one or two of the governor weights. Do this carefully, test and you should see results. The stock weights are very heavy. I have played with aftermarket weight spring kits. Working with those is a very time consuming task. The springs affect mostly part throttle shifting, the weights mostly full throttle, however, they are interrelated. Keep it simple and lighten the stock weights and try it out. It costs nothing.
I might buy a whole governor so I dont mess with the stock one.. so just shave a little off the weights I dont want to mess with part throttle settings at all it drives nice the car just shift wot to early.
Old Oct 22, 2020 | 05:17 PM
  #44
bjankuski's Avatar
bjankuski
That will be tough to do, try slightly heavier springs when taking some weight off the stock weights. That may give you the same part throttle shifts with more RPM at the WOT shifts.
Old Oct 22, 2020 | 05:34 PM
  #45
383 First's Avatar
383 First
If i take weight of just the weights dont touch the springs part throttle will shift sooner or later?
Old Oct 22, 2020 | 05:44 PM
  #46
84 4+3's Avatar
84 4+3
Yes we do...
Manually shift and switch to atco on a cool day. That can be your Hail Mary for an 11.99.
Old Oct 22, 2020 | 05:50 PM
  #47
383 First's Avatar
383 First
yes we are going to try atco too my wife likes island tho I always go faster myself at atco!
Old Oct 22, 2020 | 06:44 PM
  #48
84 4+3's Avatar
84 4+3
I just looked up the density info for both and right now atco is 88 feet vs 1000 for island. Thats probably it.
Old Oct 22, 2020 | 07:20 PM
  #49
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
My god...that would be so nice!!
Old Oct 22, 2020 | 07:41 PM
  #50
84 4+3's Avatar
84 4+3
I double checked that. Google published the actual elevation for one vs the DA for island. Still. Atco is at 600ish feet right now and 800 with humidity factor. Still fantastic.
Old Oct 22, 2020 | 07:45 PM
  #51
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I'll say. We get 6000-9000 around here.
Old Oct 22, 2020 | 08:08 PM
  #52
84 4+3's Avatar
84 4+3
Perks of living at sea level. About the only thing this state has going for it.
Old Oct 22, 2020 | 08:14 PM
  #53
TA's Avatar
TA
You need to get to Atco in late November, early December. On occasion you will get mineshaft air days where you’ll see -2000 DA days. For my car that was 3/4 of a second quicker than on hot/humid summer days.
Old Oct 22, 2020 | 08:59 PM
  #54
383 First's Avatar
383 First
Well if went 12.3 at 200 da or so that day wonder what it would do in -2000 DA...lol
Old Oct 22, 2020 | 10:28 PM
  #55
bjankuski's Avatar
bjankuski
later by a little bit.
Old Oct 22, 2020 | 10:38 PM
  #56
383 First's Avatar
383 First
Ok.so not anything terrible?
Old Oct 23, 2020 | 07:59 AM
  #57
bjankuski's Avatar
bjankuski
Correct
Old Oct 23, 2020 | 09:18 AM
  #58
383 First's Avatar
383 First
Correct
thanks for the info might be hitting the track tonight see if we can improve the ETs she will have to manually shift for now until I can do the governor ..
