Ball joint issue
What are you specifically looking for here?
Which brand do you recommend to repair Fiber for car Floors? Your question and the title of this post are kind of vague but if you have a hole in the fiberglass floor of your Corvette you can fix it with normal Fiber Glass components. I would use a medium weight fabric and do a couple layers to make it strong again. Getting the surface prepared to accept a new layer will require some work. If you have never made or repaired anything made from Fiber Glass you might seek some help from someone with experience.
Ball Joint Issue? Please elaborate on this one or we will be shootting in the dark. I use MOOG Ball Joints on both of my Corvettes. Please lay out the question and we can help you out.
Every Forum Member has a "Profile" that you need to fill out. Put any and all information about your particular Corvette. We need to know Year, body style, transmission type, any modifications done to the Corvette. As much as you can tell us will only help you in the long run. This allows us to know what Corvette you are talking about and saves us from asking the same questions over and over.
Anxious to help!
