View Poll Results: To drill or not to drill
Drill baby drill!
2
50.00%
Don't put holes in your car! Are you crazy?
2
50.00%
Voters: 4. You may not vote on this poll
Exhaust Cleanup
Old Oct 24, 2020 | 05:02 AM
Star Drive's Avatar
Star Drive
3rd Gear
Default Exhaust Cleanup
Well I have a blown head gasket. In the process of tearing my engine apart I decided I would like to clean and paint everything as I am not going to get a better opportunity. I picked up some VHT flameproof rattle cans for my exhaust manifolds. The manifolds are brown with rust (the only rusty part of my 93 LT1 coupe). The manifolds and cats have heat shields that look riveted on. My question is am I good to drill these rivets? I have a rivet gun and rivets but I am a little nervous about doing permanent damage or bleeding heat. I never did anything like this before. I wouldn't know how to clean it without removing the heat shield. Thanks
Old Oct 24, 2020 | 07:13 AM
84 4+3's Avatar
84 4+3
For exhaust manifolds, I was told spray graphite. Works better than paint. Ive used the VHT before and it does burn off..
I can't comment on the heat shields, mine are bolted on.
Old Oct 25, 2020 | 09:29 PM
cv67's Avatar
cv67
St. Jude Donor '05
POR 15 makes a nice product for those that wont burn off
Old Oct 28, 2020 | 08:51 AM
Furias15x's Avatar
Furias15x
I would keep the heat shields on. Anything to reduce the heat in engine bay. Clean them and tape them off and then paint your items.
Old Oct 28, 2020 | 08:55 AM
aklim's Avatar
aklim
Another option to fix the heat is to have a set of LT headers that are ceramic coated installed.
Old Oct 28, 2020 | 09:16 AM
SH-60B's Avatar
SH-60B
I'd leave the cats alone. Those can't even be seen from above.
Old Oct 28, 2020 | 09:34 AM
Alejandro Guerrero's Avatar
Alejandro Guerrero
I agree, headers are the way to go if you can afford it.
To Exhaust Cleanup
