Early vs. Late C4 IRS?
Jacking on a c4 is the frame pinch points only. I never saw an easy way to do it with the suspension out back.
The earlier geometry will turn in quicker and lanch harder in a straight line but be slightly skittish cornering at the limit and under braking on bumpy tracks compared with the later.
Will
Early C4 IRS is easy to find and relatively cheap, but the later IRS seems scarce and expensive. If I can use the earlier parts but then adjust my frame pickup points, that would save me quite a bit of money.
The knuckles are different enough.... the pickup points for the camber arm and trailing arm are the same, the actual difference is the bearing register/spacer/caliper bracket thickness. However the step ring that locates it on the actual knuckle is a different diameter and its not a simple swap. The outer stub axels are longer on later suspension as well.... this is where the additional width comes from on later suspensions.
People have narrowed the late suspensions inorder to use ZR1 rear wheels. Theres an old pdf writeup somewhere on here about machining the spacer blocks and using early outer stub axels. FYI C4 ZR1s all used the early narrow rear suspension widths as they had 36mm offset wheels... I've never bothered to look at the inner camber arm mount on a ZR1 to see if they have the early or late type.
Will
Will
Will
Will
The only thing is if you are worried about antilock brakes...... 84-85 C4s didn't have it (only 86-88 did) and while drilling a few holes in the caliper bracket spacer for the sensor is easy, 84-85 outer stubs don't have provisions for mounting the reluctor rings. So if you're worried about that buy parts accordingly. Shouldn't be a problem with a C3 suspension swap.
I want to point out that theres nothing wrong with the early suspension geometry..... it's actually better for all out performance. GM changed the geometry to accommodate the older age group of people buying C4s and driving them at relaxed rates rather than full on track driving them. Same reason they softened up the spring rates, the 2 changes actually went hand in hand.... softer springs meant faster suspension travel and therefore faster camber change on the rear..... they changed the rear roll rate to accommodate the softer springs nedded to keep senior citizens buying the cars.
If the narrow track width works better for you then use early suspension..... if the wider works then use the later..... it's not a big deal either way for 99.9% of people.
Will
the 'early C4 suspension is 1984-1987. The late C4 suspension is 1988-1996.
also be aware that depending on the car the C4 suspension can have either a Dana 36 or Dana 44. I believe all 1984 cars had the D36, after that auto cars got the D36 and manual cars got the D44 (I think). There was a number of gear ratios offered thought the years so you may want to check which ratio the rear end has.
One other thing to note, that might have been mentioned already, the early C4 suspension used an Internal drum rear park brake, whereas the late C4 suspension had the park brake integrated into the rear caliper. Z51 cars from 1988 onwards also got the J55 13in (2 piston caliper) front brakes.
finally, there were a whole lot of spring rates offered in the C4, so be aware that the spring rates are not all the same, so you will want to do some research to determine what spring rate will work for your C3. The same goes for C4 anti-roll bars.
There is no roll steer with an IRS. That's only a function with a solid axle as it literally steers the axle when the trailing arms go through their arcs. With a C4's IRS, the rear steer is completely controlled by the toe links. They don't always perfectly match the travel of the trailing and lateral links, and when that happens we get "bump steer." To my knowledge, there is not a difference in bump steer between the early and late suspensions. If there is, that can be adjusted out with a bump steer kit (I don't even know if such a thing exists, because it may not be needed).
As far as I can tell, there is no difference in rear suspension parts for the ZR1 vs the regular 92-96 C4s, and the 88-91 is the same for all C4s in those years. The only difference to the 92-96 spindles being the reluctor ring. This is confirmed in the parts manual I have. IOW, the ZR1 uses 36mm offset wheels purely because of its wider body work.
As far as I know, the early C4 front suspension is generally considered faster in cornering, but not the rear. The earlier rear has a little more (negative) camber gain with roll, but the higher roll center with correspondingly higher jacking effect.
Since the OP wants to adapt a C4 rear suspension and diff to a C3, I'd say use whatever is easiest to fit. The performance differences are not enough to worry about in this application, and either will be light years better than the stock C3 rear suspension. It's an awful thing. Also, since you'll be fabbing the frame mounts anyway, you can set the trailing arms frame pivot heights anywhere you want. And if you want to lower the diff-mounted pivot point for the lower camber rods, you can easily enough make a bracket to do that (or check out Doug Rippie lowering brackets).
Just interested in your input. Thanks.
The previous owner of my car had amassed all the parts to do the swap. He never got around to it, and sold it to another C4 autocrosser in his region. That guy did do the swap, and some national champion caliber drivers have pronounced that car as the best handling car they've ever driven (and they've driven hundreds of cars competitively). It seems to me that an early front end a later rear end are the perfect combo. If I hadn't sold the car, I'd probably be working on that swap right now...
The main issue I have ever heard regarding "lots of" anti-dive is that it tends to bind up the suspension under hard braking (effectively locking/increasing the spring/wheel rates). Are there any additional reasons that you're aware of?
I have a '96 suspension on the front. When I first installed the C4 suspension I duplicated the stock A-arm positions on my custom brackets on the frame, but I can reduce the anti-dive by moving the front A-arm bolt down one hole in the bracket. Your comments above have piqued my interest in trying out a reduction in the anti-dive. I haven't done the math yet to see what the change in static caster would be with just lowering the front of the A-arm. I suspect minimal, but I also am under the impression that "flattening" the A-arm angle would also decrease the outside tire caster gain under lateral weight transfer during cornering. I'm just trying to get comfortable with this change, so that hopefully there's a net increase in front grip. I'm running coilovers, and have heavier springs if the need appears.
Thanks again.
It does act like the front spring rate is increased though, because it understeers on the brakes. I've heard anti-drive referred to as a "geometric spring," which is what it feels like to me. But I've not been able to completely work out how this would happen. The geometry should add a constant vertical force into the frame that only varies with braking force, and so one would expect the spring and sway bar rates to still determine roll resistance (which is what determines handling balance). However, as the car dives or rolls, the CG would get lower which increases the anti-dive even if the force and vector angle stay the same. I don't know if that accounts for all this effect or not, but in some way it seems to add to the effective spring rate. Note that if you took out the anti-dive and compensated with a stiffer front spring, you'd have the same effective spring rate as with anti-dive. However, you would have presumably compensated by also increasing the rear spring or sway bar rate or by decreasing your front swaybar rate in order to keep the balance. What you end up with, then, is a more consistent handling balance vs the car with lots of anti-dive, which may be close to neutral off the brakes but understeers a lot with the brakes on.
