How high is high enough for a front lowering kit install?
Old Nov 7, 2020 | 09:56 AM
TommyFox's Avatar
TommyFox
Default How high is high enough for a front lowering kit install?
Will jack stands on the front fully extended get the car (87) up high enough for front spring removal? For now I'm doing the lowering blocks and bolts in rear instead of coil overs.
Old Nov 7, 2020 | 11:00 AM
NASCAR314's Avatar
NASCAR314
Yes, as long as they are the taller / stronger ones like 3 ton or more. That's the easy part, getting stock rate spring in and out is a pain without spring compressor, BUT is doable with patience
Old Nov 7, 2020 | 01:00 PM
383vett's Avatar
383vett
I've had my spring out a few times while on jackstands. No problems.
Old Nov 7, 2020 | 03:36 PM
TommyFox's Avatar
TommyFox
Not following how this spring could be compressed for removal?
Old Nov 7, 2020 | 09:27 PM
NASCAR314's Avatar
NASCAR314
I've never used the tool but this is it: https://www.freedomracing.com/leaf-s...33432-a-u.html
I've done many and found other methods work. The tool somehow "flattens" the arch in the spring to enable easy side to side movement of the spring thru the frame / motor cradle. Stiffer springs don't arch as much and are easier yet.
Old Nov 8, 2020 | 12:49 PM
TommyFox's Avatar
TommyFox
Is it extremely difficult to work the spring out without one?
Old Nov 10, 2020 | 07:25 PM
Mixednuttz's Avatar
Mixednuttz
2023 Corvette of the Year Finalist - Modified
2022 C4 of the Year Winner - Modified
Finalist 2020 C4 of the Year - Modified
I didn't use a spring compressor when I changed the front spring (to a Z51 spring) on my 85 a month ago. I did have to lift the front end quite a way but once I found the right height, it wasn't all that difficult. I did have the lower control arms off to replace them at the time, so they weren't in the way for the spring swap.
Old Nov 10, 2020 | 07:37 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I didn't use a compressor (other than the ones that are built into the car already) to remove the spring on my '89 Kart, either.
YOU DON'T NEED A TOOL! The car already has a spring compressor built right in! It's called.....the lower control arm. Jack stand the car like 383vette said, put your floor jack under an arm, break apart the lower ball joint, then loosen the control arm bolt/nuts. Swing the arm down until it goes no farther...repeat on the other side. You MAY want to remove the sway bar end links, but you may not have to, either.
To How high is high enough for a front lowering kit install?
