Grinding turning right under acceleration
Old Nov 10, 2020 | 04:51 PM
95Bluebyu's Avatar
95Bluebyu
2nd Gear
Default Grinding turning right under acceleration
1995 manual that I just finished an engine refresh. Took it for the first drive and it has a grind when accelerating while turning right. It's really noticeable on slight right turns. The grind feels like it is right at the front of the trans. It didnt make this noise/feeling when I started working on it in July. It doesn't feel like a wheel bearing or dif. I had to remove the bellhousing inspection plate when I removed the oil pan, is it possible that I installed it weird and its rubbing on something? Any ideas are appreciated. The chuckster sounds like he had the similar issue but the link he posted years ago is dead so I couldn't read it. Thanks!
