Diff noise
Old Nov 11, 2020 | 07:59 PM
Stingraynut's Avatar
Stingraynut
Default Diff noise
If a suspension bush in the diff batwing, or another part connected to the diff was very worn, could it transfer diff noises to the cabin?
The noise I'm hearing is definitely diff noise, it's like putting your ear to a screwdriver handle while holding it on the diff casing
I can hear the lash effect noise changing between lightly accelerating , freewheeling and backing off the throttle, but it's a metal on metal noise, not a whine or hum
I live in the tropics and rubber doesn't like the heat. I've hardly driven the car for years because of poor health and this noise suddenly appeared and seemed to change during only 30 miles of short road testing around the suburbs
The rear sway bar rubber bush totally failed and it made a clonking sound on bumps and transmitted road noise when it was metal on metal
I can't see how a diff bearing could fail when it sits in oil and hasn't been driven. When I do drive I don't drive hard, no hard starts or competition driving etc
I'd appreciate any advice, especially from anyone who has had a bush fail on the batwing or part connected to the diff, before I take it to a mechanic and put it up on a hoist.
I'd like to be prepared beforehand to know what to check and look for.
1988 Auto, standard Dana36 with Posi LSD. I've had the car since 2003. I've replaced the dog bone bushes, sway bar bushes. It has new wheel bearings and UJ's.
Old Nov 11, 2020 | 08:13 PM
JD1964's Avatar
JD1964
Where is the car parked? Is it on a non paved surface where its possible for an oil leak to go undetected over a period of time. Low oil could be the issue. What about mileage on the diff oil? Has it ever been changed?
Old Nov 11, 2020 | 11:12 PM
Stingraynut
Car is parked in a garage on tiled floor, diff oil level checked after noise began and was perfect. No oil loss, added a bottle of GM LSD additive in case it helped. No change.
The most important part of my post is 'The noise is like putting your ear to a screwdriver handle while holding it on the diff casing'
To Diff noise
