Tunable side effects exhaust?
Old Dec 3, 2020 | 08:59 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Originally Posted by 1990steelbluec4
I believe you're wrong
I declare you loser of the bet! LOL
Old Dec 3, 2020 | 09:08 PM
GREGGPENN's Avatar
GREGGPENN
Originally Posted by 383vett
Nice looking system that looks nice on a car. You probably stand to lose at least 20 hp though. The exhaust hits a wall and has to make a 180 to exit out the other direction after meeting incoming exhaust head on.
I don't object to your conclusion of power restriction AT ALL, but I question your observation that exhaust meets itself "head on". I don't see that happening but it's probably difficult to understand the pathway looking at the casting. If someone wants (as is still curious after my prior explanation), I can attempt to use PAINT to superimpose arrows -- indicating the flow.
I've toyed with the idea of using cutouts to install a "trap door" at the send 90-deg turn...then connecting that to the outlets. OTOH, cutouts aren't cheap. If I could find a way to weld a 1x3 connector to a flattened/ovalled 3" pipe, that might make more sense. That way, the original castings would remain resellable -- if I liked the result. Of course, it would be LOUDER...and might require a mid-section muffer (again).
BTW, that's my only thought on how to make it "tunable"....to make an electronic dump directly into the outlets BEFORE the turn up to the mufflers.
Old Dec 3, 2020 | 09:30 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
I knew the answer, I was just trying to be polite.
