Removing a one piece balancer
Old Nov 23, 2020 | 06:58 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Removing a one piece balancer
Anyone here take a one piece balancer off with the engine in the car?
The blower kit uses a one piece balancer.
I chasing down a leak at the front of my engine and I'll be pulling the front cover to replace all the seals.
Can it be done w/o removing the steering rack?
Pic of engine before install.
Old Nov 24, 2020 | 08:48 AM
jazfe's Avatar
jazfe
It can be done. I've pulled mine twice now but the trick is finding a puller with a small enough head on the bolt that fits through the loop in the steering rack. Tedious for sure. My balancer is stock and clears the cross member. Not sure about yours. I also made an install tool because I could not find one to buy locally and at the time I did not want to wait days for one to arrive in the mail. Here is a pic of my install tool. I found the instructions here on the forum but have lost the link.
Old Nov 24, 2020 | 12:39 PM
BrianCunningham
Yeah, I'd had the stock two piece off
Trick was not letting the PS cooler slice me.
Old Nov 25, 2020 | 01:30 AM
blackozvet's Avatar
blackozvet
Get a 16 mm bolt x 125 mm (or 5") long from the fastener store.
Use it with the normal balancer removal unit and it should be the correct length that the balancer comes off with room to spare.
Old Nov 29, 2020 | 06:08 PM
BrianCunningham
I borrow'ed a puller from O'reilly auto parts that I think is large enough.
Need to disconnect the supercharger and it's brackets so I could get to one of the waterpump bolts.
Not that the one behind the PS pump pulley is ever easier to get to
Especially with a vacuum vent line to the Opti in the way.
Old Nov 30, 2020 | 01:05 AM
Nomake Wan's Avatar
Nomake Wan
I feel your pain. Ended up just using a long socket on a universal joint pushed through the power steering pulley hole to get that one out. I look forward to putting it back in.
Old Nov 30, 2020 | 10:42 AM
BrianCunningham
Is the PS pulley removable?
Old Nov 30, 2020 | 11:50 AM
Nomake Wan's Avatar
Nomake Wan
I'm not sure, but I didn't bother. It has an odd cap on the center of it I didn't want to mess with. Fortunately the holes in the pulley were large enough to get the socket and extension through. Almost as if GM designed it that way...
Old Nov 30, 2020 | 12:53 PM
BrianCunningham
LOL
I'll definitely try it that way when I go to put it back on
To Removing a one piece balancer
