C4 TPI Bolts
Old Nov 26, 2020 | 11:36 PM
Gimpy2781's Avatar
Gimpy2781
1st Gear
Default C4 TPI Bolts
I just recently picked up a 1990 C4 L98 Vette, clean car, 65k miles, the previous owner took the motor apart due to a dry rotted head gaskets I’ve got it all back together except TPI system, some bolts for the system, are missing; can I use a standard bolt from a part store in replacement of the missing hardware, or does it need to be a specific product??
thanks In advance
Old Nov 27, 2020 | 01:10 AM
gerardvg's Avatar
gerardvg
thanks In advance
Hi the intake runners use metric bolts M8 1.2 x 30mm long, there is nothing stopping you using normal hex bolts however some lower ones don't have much room for a socket.
maybe Allen key type bolts will look better?
You may be able to get a set of second hand intake runner bolts on ebay? Or a car wrecking yard.
Good luck
Oh tip ... before bolting the intake runners up, test the fuel pressure make sure none are leaking.
the o rings can easily leak.
simple to rectify when the fuel rail is bolted in place, without intake runners bolted together.
Gerard
Old Nov 27, 2020 | 01:59 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
For runners, plenum and intake I prefer OEM style bolts.
You might see if a good local hardware shop can custom order the bolts needed, though e-bay or used parts vendor would be a quicker path.
Old Nov 27, 2020 | 09:27 AM
l98tpi's Avatar
l98tpi
Max G’s
There are fastener companies out there you can get the bolts from. Best I remember on the intake manifold bolts is there were two different sizes (length) used. Hoefully you have all to reference.
Good Luck
Old Nov 27, 2020 | 11:53 AM
cv67's Avatar
cv67
St. Jude Donor '05
Smaller the head of the bolt the better...I found an adapter to 1.4" and a lfex extension makes starting some of them easier.
NEver liked the factory ones but under the runners theres hardly any room.
Old Nov 27, 2020 | 08:00 PM
89dd's Avatar
89dd
Try picking up a set of Allen Head bolts.
They look cleaner, and with a ball end driver it makes installation and removal a lot easier.
To C4 TPI Bolts
