Storage additives?
Old Nov 28, 2020 | 11:12 AM
Whaleman's Avatar
Whaleman
Originally Posted by jv9999
Heet is methanol. The "10" in E10. The absorption of water is what makes it corrosive.
Well, I will never add any more. Thanks for the info. Dan
Old Nov 28, 2020 | 02:02 PM
ctmccloskey's Avatar
ctmccloskey
Here in Virginia we too have that 90% gasoline crap they force our cars to drink.
I have replaced every diaphragm and rubber component I can get to. We also have had to replace a Fuel Supply Line on my 1988 Corvette. It sat for a while and the car's fuel lines was getting smaller and smaller inside as the water rusted it's way through the Steel High Pressure Fuel Line. The pressure was there there and okay but there was insufficient VOLUME of gasoline due to rust blockage that started inside the line at the lowest spot in the system.
After replacing the fuel Supply Line and a couple brake lines I have it somewhat under control. The ONE thing I do is use the Lucas Brand of Ethanol Treatment. I put a whole can in each Corvette and I keep the tank full up to the top all the time while it sits through the winter. Anything that is going to sit for three months or longer should get it added to it.
I do not believe,support or purchase Snake Oils and this is clearly NOT one of them. Keeping the tank full minimizes the amount of condensation that will occur inside the fuel tank. They taught us to never leave any fuel tank empty due to the risk of condensation forming and you have water in your fuel. That is a lot more exciting at 10,000'!
I DO Use Ethanol Treatments to minimize the fuel turning bad over a few months. Especially in my Lawn equipment.....
Old Nov 28, 2020 | 02:07 PM
Dave Witman's Avatar
Dave Witman
The C5 I store with full tank and with techron and star tron additive. The old vettes I store with Star tron.
