Coolant Recommendation
Old Dec 1, 2020 | 12:29 AM
mfowler's Avatar
mfowler
Default Coolant Recommendation
1990 L98. Preparing to install a new water pump. Which coolant do you guys recommend to put back in her?
Thanks!
Old Dec 1, 2020 | 12:38 AM
aklim's Avatar
aklim
Besides the regular green stuff?
Old Dec 1, 2020 | 12:40 AM
mfowler's Avatar
mfowler
Any particular brand better than others? 50/50 mix or use concentrate and mix my own?
Old Dec 1, 2020 | 12:48 AM
vader86's Avatar
vader86
I use Prestone 50/50 unless I feel like tweaking the ratio.
If you only drive in summer you don't need it 50/50, for example.
Old Dec 1, 2020 | 08:47 AM
mfowler's Avatar
mfowler
Thanks Vader!
Old Dec 1, 2020 | 08:54 AM
84 4+3's Avatar
84 4+3
I run prestone green, at a 60/40 ratio. (Little more water helps with cooling, better thermal conductivity) measured by volume. Its close enough. My garage only goes into the 20s on even the coldest days so it isn't a concern. Change it out every few years.
Old Dec 1, 2020 | 11:46 AM
ctmccloskey's Avatar
ctmccloskey
A second on "Prestone". I use it in a mixture of 70% water 30% anti-freeze as where I live it doesn't get that cold and we deal more with a warmer humid climate. The more water the better the heat transfer, anti-freeze does not transfer heat as well as water. The second thing is to replace the radiator cap every few years as they loose their pressure rating over time. A weak radiator cap will allow an engine to overheat as it can no longer hold the pressure.
Old Dec 1, 2020 | 12:21 PM
JoeNova's Avatar
JoeNova
I use coolant.
I don't care because my engine doesn't either.
To Coolant Recommendation
