Which Heads Are Better?
Old Dec 6, 2002 | 06:54 PM
MagRed_04's Avatar
MagRed_04
Default Which Heads Are Better?
GM FastBurn or AFR 190's? Any Pros or Cons? Suggestions?
Old Dec 6, 2002 | 07:05 PM
gtsyellow's Avatar
gtsyellow
Default Re: Which Heads Are Better? (Vette_Crazy)
afr 190...this is a no brainer. #1 the fast burn has a raised runner which means you run a scoggin doggy tpi base or a miniram 3, the fast burns don't flow as well as the 190 and they have larger runners which make less velocity.
Old Dec 6, 2002 | 08:15 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Which Heads Are Better? (gtsyellow)
the afrs will out flow them from top to bottem with better velocity too :cheers:
Old Dec 6, 2002 | 09:20 PM
vader86's Avatar
vader86
AFR 190s
Old Dec 6, 2002 | 10:17 PM
lcvette's Avatar
lcvette
Agreed the AFR heads are a choice product! just be aware that some minor machining/deburring of the oil return passages is recommended as the oiling return holes are simple drilled holes that are a bit high for good return and cause some puddling above the valve cover/cylinder head mating surface which in my experience has lead to leaking or hard sealing valve covers. but the performance is excellent from these heads!
Chris
Old Dec 6, 2002 | 11:21 PM
Speedracer176's Avatar
Speedracer176
AFR190 heads will out flow Fast Burn heads out of the box. Lets not get into ported one either!!!
But like said before, with the fast burns you need to get a new intake to match the runners. The afr will work with any standard sbc intake
Old Dec 7, 2002 | 12:37 AM
tpi 421 vette's Avatar
tpi 421 vette
Default Re: Which Heads Are Better? (Speedracer176)
Like everybody else has said, defineitly AFR 190's are the way to go.
Old Dec 7, 2002 | 09:17 AM
LD85's Avatar
LD85
Default Re: Which Heads Are Better? (tpi 421 vette)
Just another consideration here, I will be buying Canfield 220CC for my 406! They make a 195 CC, and dont pay attention to the pricing on the home page of Canfield. Email me if you want a link to the best pricing I have found so far on their heads.
Also, in doing a side by side the Canfields are vrtually identical in flow and better flow in spots on the 220CC version. You can go to the AFR site and the Canfield site and print the flow charts and do a side by side!
http://www.canfieldheads.com/sbc.html
just my .02!
[Modified by ld85, 9:23 AM 12/7/2002]
Old Dec 7, 2002 | 09:02 PM
eguyett1985's Avatar
eguyett1985
I've got the Dart Pro1 200's on my new 408. The flow numbers on them are extremely good and the quality is very nice. They are definetely worth looking at.
To Which Heads Are Better?
