93 C4 long crank time
Old Dec 28, 2020 | 12:19 PM
Supravisor's Avatar
Supravisor
4th Gear
Default 93 C4 long crank time
My 93 C4 will start instantly when cold , after short run up to temp and a few miles stop and let it sit extended crank and dark exhaust from right side exhaust and rich smell ,and engine stumbles . I am guesssing bad injector leaking and flooding . Any sugestions ?
Old Dec 28, 2020 | 02:12 PM
s carter's Avatar
s carter
your on the right path, now you need to get a gauge on the test port and prove it or rule it out. As a maintenance item It's good idea to look at the O-2 sensor make sure it's functioning correctly they do have a service life, I have seen many here recommend to replace them like 36,000 to 50,000 miles or every few years.
Old Dec 28, 2020 | 04:31 PM
SloJo's Avatar
SloJo
Push your gas pedal all the way to the floor, this tells the computer you're in flood mode and it doesn't fire the injectors. If it starts right up then they are flooding.
Old Dec 28, 2020 | 09:21 PM
dizwiz24's Avatar
dizwiz24
Or the fuel system isnt holding pressure
Old Dec 29, 2020 | 12:08 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Originally Posted by ihatebarkingdogs
Fuel pressure regulator diaphragm is ruptured. The vacuum line goes into the RH bank. The smoke is on the RH bank.
O2 sensors have zero influence for starting.
This.
It will almost certainly be the FPR or a leaking injector.
Pull that vac line off the FPR and see if it is wet, if it is, you may need a new FPR.
While youre at it, hook up a pressure gauge to the fuel rail and turn key to on, watch the pressure come up, and then turn key off. Don't need to start the engine, just let the fuel pump do it's start up cycle. Fuel pressure should hold for a fair while, and it should be around 40-43.5psi.
Old Jan 2, 2021 | 07:57 PM
93Rubie's Avatar
93Rubie
Are the injectors original? They may be shorting internally, the Multec 1's are known for this. This was the cause of my issues in the past. No conventional testing methods found it but a AMP pattern on a oscilloscope did. Worth checking their resistance with a Multi-meter at least.
ANY FUEL leak from a ruptured FPR would effect ALL engine operation at ALL TIMES on BOTH BANKS. The LT1 intake is open inside of it. A ruptured FPR will put a LOT of fuel into the intake.
Replacing 02's as maintenance is a myth. They may get a bit lazy over time but unless its a problem....not worth it. Mine are original and the car runs perfect, fuel mileage is excellent. It even makes the HP its rated at, the 02's don't do anything at WOT, my point is the engine is healthy.
To 93 C4 long crank time
