Code 36...again. Please help!
Thanks!
I can burn the chip for you and send it your way, and it'll be a hell of a lot cheaper than trying to find one online, that I can guarantee. I still have some of these chips laying around so I don't mind. However, you would still need to purchase the adapter to make that work. If that's a route you're interested in, feel free to shoot me a PM. Feel free to let others chime in with their experience though! I don't own an earlier car, but I have burned chips for other members with earlier cars and they all worked out. I don't do mail-order tuning, just making small changes to the code like changing error codes and fan activation temperatures and such.
Best method is what Nomake Wan said, get the ECM MEMCAL modified, only change needed is disabling code 36. Good idea to update to flash as Wan also mentioned, as the old EEPROM can wear out eventually and few have the equipment to burn one anyway. I did the disable, though I had a pro change the MEMCAL for new fuel injectors at the same time. Works fine with a typical replacement MAF from Rockauto.
Make sure to ask for a digital copy (as in a computer file) of the original MEMCAL as well as the modified version, just in case.
Tons of other threads for this on the site, search around.
I had the same thing happen on mine and spent numerous hours trying to fix it. I had multiple small vacuum leaks on cracked vacuum hoses and also PVC hose like in the vid. I finally fixed it after fixing all the vacuum leaks.
A very small vacuum leak can cause an irritating redundant code 36 until 'Kingdom com'....
I had this code 36 set on both my current 87 and 89 due to a VACUUM LEAK ONLY. Nothing else faulty.
More than once. You can replace MAF sensors and relays until one is blue in the face but if you have a slight vacuum leak you will most likely get a code 36. I just recently replaced my water pump and forgot to connect a vacuum hose under the throttle body.
Guess what ? Code 36....
Burn-off cycle explained:
Here's an example log to illustrate what is going on during the burn-off cycle from the ecm's perspective (use chrome to open link and wait for it to generate chart):
https://datazap.me/u/tequilaboy/burn...7-8&mark=64-67
After a 5 second delay after the ignition has been switched off, the burn-off cycle will be activated for one second and the resulting voltage will be monitored and compared against pre-set limits. This can be seen while scanning by observing the unlimited airflow signal. Converting from voltage to flow using the MAF tables below, the acceptable flow range is between roughly 5 gm/sec and 36 gm/sec (which corresponds to 400 mv - 1.9 v).
Look for the prominent IAC reset cycle to indicate when the ignition was switched off and note the drop in the unlimited airflow signal that occurs 5 seconds later (see the yellow markers).
In this log you will see the unlimited airflow signal bouncing between 27 and 29 gm/sec (or around 1.65 volts) during the burn-off cycle. This is within the acceptable range, so no failure was detected in this example. Unfortunately, I don't have any example logs showing what happens with a failed maf or with failed relays, but you are free to imagine how the signal will be affected.
Note: The normal maf control signal (mass airflow) is limited by the max maf vs rpm table, so you typically won't see the burn-off cycle by observing the mass airflow signal directly unless it should happen to fall below the limit value. In this particular case, the max maf limit was set to 26 gm/sec below 400 rpm. With standard tuning, this limit would be set to 23 gm/sec below 400 rpm.
Some mafs simply do not fall within the acceptable voltage range. If all else fails, you can re-tune the code 36 parameters, disable code 36, or use a modern maf that does not require burn-off and disable code 36 in parallel, or live with the code/ses lamp.
This data was obtained by scanning at 8192 baud with DataCat. Scanning with proper tools is essential for a thorough diagnosis. I can't emphasize this enough.
Acceptable voltage/flow range obtained from MAF tables 1 and 2 shown in green:
Volts Grams/sec
01.92 37.13
01.90 36 *
01.83 33.75
01.74 30.56
01.65 27.56
01.55 24.94
01.46 22.28
01.28 18.78
01.10 15.36
00.91 11.95
00.73 9.16
00.55 6.83
00.40 5 *
00.37 4.94
* You really need to interpolate between points to get the exact flow values at 400 mv and 1.9 v, but this is close enough for this discussion.
parameters involved:
SCALAR: MAF Burn off time 1.00 seconds
SCALAR: MAF Burn off delay 5.00 seconds
; ERR # 36 Params
; >> MAF Burn off Diag <<
LC221: FCB 3 ; 0.3 Second Dly prior to Burn off CAL = Arg * 10
LC222: FCB 6 ; 6 fails req for ERR #36 If HLM air meter
LC223: FCB 95 ; 1.90 VDC, Fail B/O test if HLM A/D GT 1.90 VDC
LC224: FCB 20 ; Fail B/O test if A/D < 400 mvdc
Note: this car has had some tuning of the MAF tables, so the values shown here do not necessarily reflect standard tuning. They are shown for reference purposes.
TABLE: MAF Table #1
Volts Grams/sec
01.46 22.28
01.28 18.78
01.10 15.36
00.91 11.95
00.73 9.16
00.55 6.83
00.37 4.94
00.18 3.59
00.00 9.16
TABLE: MAF Table #2
Volts Grams/sec
02.19 47.63
02.10 44.44
02.01 40.69
01.92 37.13
01.83 33.75
01.74 30.56
01.65 27.56
01.55 24.94
01.46 22.31
TABLE: MAF Table #3
Volts Grams/sec
02.93 82.03
02.83 77.16
02.74 72.30
02.65 67.76
02.56 63.22
02.47 59.01
02.38 55.12
02.29 51.23
02.19 47.66
TABLE: MAF Table #3
Volts Grams/sec
02.93 82.03
02.83 77.16
02.74 72.30
02.65 67.76
02.56 63.22
02.47 59.01
02.38 55.12
02.29 51.23
02.19 47.66
TABLE: MAF Table #4
Volts Grams/sec
03.66 134.47
03.57 124.98
03.47 117.07
03.38 110.74
03.29 104.41
03.20 98.61
03.11 92.81
03.02 87.54
02.93 82.27
TABLE: MAF Table #5
Volts Grams/sec
04.39 206.19
04.30 195.68
04.21 185.98
04.11 177.08
04.02 167.38
03.93 158.48
03.84 150.40
03.75 142.31
03.66 134.23
TABLE: MAF Table #6
Volts Grams/sec
05.12 254.00
05.07 254.00
05.03 254.00
04.98 254.00
04.94 254.00
04.89 254.00
04.85 254.00
04.80 254.00
04.75 254.00
04.71 254.00
04.66 247.03
04.62 239.06
04.57 232.09
04.52 225.12
04.48 218.14
04.43 212.17
04.39 206.19
TABLE: Maximum Air Flow vs. RPM
RPM Grams/sec
6400 255.00
6000 255.00
5600 255.00
5200 255.00
4800 255.00
4400 255.00
4000 255.00
3600 255.00
3200 255.00
2800 254.00
2400 181.00
2000 125.00
1600 85.00
1200 55.00
800 35.00
400 26.00
00 26.00
As can be seen, the IAC cycles fully open, fully closed and then opens to the start position to prepare for the next start-up. 160 counts is the start position for 1989 cars (144 counts for earlier cars). This is all normal behavior. I've shown this signal because it serves as very obvious visual indicator of when the ign is switched off.
If scanning at 160 baud, you may not see anything (or only 1 or 2 samples) after ign off due to the slow frame rate and limited (25 byte) 160 baud data stream, so this may explain what you see with your scanner. I don't have much 160 baud data on hand to confirm, but I can do some digging. Sorry, I don't have a laptop available at the moment and I don't want to drag this pc out to the car to test (but have done so in the past). Its an all-in-one touch screen, so kinda like a big tablet, but also kinda ridiculous to use in the car.
Back to code 36: During the 1 second burn off, if the maf voltage is outside of the 400mv-1.9 volt range, a counter will be incremented. After 6 counts, the code 36 dtc will be set. 6* 6.25 ms = 37.5 ms, so it doesn't take long.
You should be able to see this behavior on the maf signal wire with a voltage meter or o-scope, but it is much easier to scan assuming you have the right tools available.
Note: The light green line (unlim airflow diag) is the important signal here since the mass airflow signal is being limited by the table and does not show the effect. The unlimited airflow signal directly follows the a/d conversion (including scaling) but without limitation. It is therefore the better indicator of the actual maf voltage.
Voltage out of range is likely due to bad maf sensor, relay or wiring issues. The behavior of the unlimited airflow signal (light green line in log) should offer a clue as to what has failed, but often it is the maf itself that is the culprit, especially with after-market or replacement mafs. No signal response would point to power issues, low voltage or high voltage out of range could be due to a short to ground or vbat, or a bad sensor.
Here's another log just for fun. Different car this time. It is equipped with a Blowerworks maf, so no burn-off and no code 36 (ever). This log includes maf voltage and exclusive maf air temp signals. Note the different behavior of the unlimited airflow (labelled as maf raw input) and mass air flow signals compared to the original log. The maf signals are not pulled up after ign off in this case due to input circuitry changes and there is no burn-off, so the signals decay naturally to zero with no flow.
https://datazap.me/u/tequilaboy/maf-...rk=28818-28865
Only thought how "fixing" a vacuum leak might trigger a code 36 is if:
a) The burn circuit is failing check.
and
b) The car is not getting to closed loop due to the vacuum change. The burn circuit is only checked after the engine has reached closed loop and turned off. This means the vacuum change prevented closed loop, so no code 36 logged even though burn circuit didn't perform properly.
Seems unlikely this would happen, I'd expect the vacuum problem was properly fixed.
and
I'm with @kael. The way I read the Code 36 DTC, it sets if the burn-off function on the previous engine shut down did not occur. The 1988 FSM (only year manual I have with a Code 36) does not explain the parameter for DTC 36 to set. But because 36 is monitoring a function that occurs when the engine is NOT running, I don't see how 36 could be set by a vacuum leak when the engine IS running. The 36 DTC shouldn't be active if the engine is running.
What exactly happens, what is the feed-back to the ECM, what circuit is the DTC monitoring, to set the 36 DTC? << These parameters are not in the 88 FSM.
