1989 convertible
Old Jan 1, 2021 | 01:15 PM
BillDurant's Avatar
BillDurant
Default 1989 convertible
All stock except last owner remover catalytic converter and heater core
I just put in a 195 thermostat. What high and low temps should it run at?
124,000 miles. Its a 6 speed
and I live in Florida
Old Jan 1, 2021 | 06:10 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Congrats on your '89 Vette.
Can't comment on temps for a 195deg T-stat as I run 160deg in each Vette.
For a little sharper accel you might pull the "frisbee" (disc) from the front of the WP pulley.
Old Jan 1, 2021 | 11:09 PM
Siveck's Avatar
Siveck
In stock form, 230 is possible especially with the ac off. AC turns fans on. 3 things I did to my ‘89:
3 row aluminum radiator
lower temp aux fan switch (maybe 200deg? Can’t remember)
180 thermostat
Rarely gets to 210f anymore. Usually runs near 200f in central Alabama heat.
To 1989 convertible
