antenna replacement tips
Old Dec 9, 2002 | 07:01 AM
alphado's Avatar
alphado
Default antenna replacement tips
The power antenna on my 1990 Coupe quit working. I found a replacement on Ebay http://cgi.ebay.com/ebaymotors/ws/eB...874342402&rd=1 It looks like a pain in the butt to change, any tips?
Old Dec 9, 2002 | 07:34 AM
Jimbo93's Avatar
Jimbo93
Default Re: antenna replacement tips (alphado)
I believe there is a Tech Tip on it. :cheers:
Old Dec 9, 2002 | 07:41 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: antenna replacement tips (Jim Holbrook)
Yes, check the tech tips, some of the ideas in there were mine.
Old Dec 9, 2002 | 11:20 AM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
I replaced mine with an aftermarket unit. It took me about 2 hours+.
Old Dec 9, 2002 | 11:32 AM
sraft's Avatar
sraft
I replaced mine yesterday-the entire job took ~45 minutes. I removed both left side tail light housings and had very good access to the antenna. I only had to get on my back for a couple of minutes to wiggle the antenna out the bottom of the rear quater panel. I don't know if removing the tail light housings is simple on the 84-90, it was very easy on my '94.
good luck,
Steve
Old Dec 9, 2002 | 01:38 PM
alphado's Avatar
alphado
What about this Hirschmann Power Antenna Replacement. Has anyone used one of these?
Old Dec 9, 2002 | 03:59 PM
Steel Blue 91's Avatar
Steel Blue 91
Turn the ignition on and turn the radio on. Now turn the radio off. If the motor runs and stops and the antenna still won't move it may be just the mast. Might be worth it to check.
Old Dec 9, 2002 | 04:10 PM
Mikez40's Avatar
Mikez40
It is really a pretty simple job. Remove rear speaker and cover on driver side for access to the cable. jack car up, remove rear tire. remove inside fender well. Then you will have easy access to remove the antenna.
That price on ebay looks pretty good. You spend twice that for a factory one.
Old Dec 9, 2002 | 04:12 PM
MagRed_04's Avatar
MagRed_04
Default Re: antenna replacement tips (Mikez40)
I did mine when I replaced the exhaust... Had easy access with the muffler dropped.
[Modified by Vette_Crazy, 4:12 PM 12/9/2002]
Old Dec 10, 2002 | 10:53 AM
brdd's Avatar
brdd
I put in a Hirschman antenna. It works fine but you will need an adaptor to connect the two coaxials. Also, you will need a schematic to hook the two power wires to the antenna power relay. You have to splice them in. :yesnod:
[Modified by brdd, 9:55 AM 12/10/2002]
To antenna replacement tips
