Transgo Kit Installed --> Help! 1-2 Problem
Old Dec 9, 2002 | 11:32 AM
CptMorgan's Avatar
CptMorgan
Default Transgo Kit Installed --> Help! 1-2 Problem
Put in a Transgo Shift Kit in yesterday and have the car back on the road. However, I’ve got some problems now:
1) 1-2 shift is now softer than before??!! I put in two washers. :mad :cry
2) 2-1 manual downshift isn’t working under no throttle or braking??!! :mad
3) No 4-3 kick down above 55 MPH at WOT (Designed that way?) :confused:
Everything else seems really good. 2-3, 3-4 shift fast and firm. At the end, I had two left over ball bearings left that came from inside the tranny: On regular and one large! No where in the instruction did I see mention of there being a bigger ball!
Please help me on this one :(
Note:
-That I have Valve Body #1
-Auto Shift
-I didn’t install the new 3-4 spring. Should I have??
[Modified by CptMorgan, 8:44 AM 12/9/2002]
Old Dec 9, 2002 | 12:22 PM
Bluevette85's Avatar
Bluevette85
Default Re: Transgo Kit Installed --> Help! 1-2 Problem (CptMorgan)
Did you reset your TV cable? This could affect the down shift.
Old Dec 9, 2002 | 12:40 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Yep...thats one reason I haven't tried to install one yet...although it is in the future mod for my '84.....need all I can get.
Hope you find out why you have this problem.
tony
:cool:
Old Dec 9, 2002 | 01:16 PM
dgoodhue's Avatar
dgoodhue
Note:
-Auto Shift
I had the left over big ball also, I have heard from a tranny builder that it is elimated because it can get stuck sometime and would burn up the tranny.
I would double check to make sure you have enough oil (check in Park with tranny warmed up) as maybe you have had some air pockets work themselves out.
Old Dec 10, 2002 | 10:56 AM
CptMorgan's Avatar
CptMorgan
I played around with the car last night and set the TV cable as tight as it will go before ratcheting back. Checked oil add it is jst above the full line. I've still go the same problems, but I can refine them a little further:
1) 1-2 shift is still softer than I think it should be.
2) 2-1 manual downshift is very slow (1-3 sec) when under no throttle or braking??!!
3) Can't get locked into OD below 50-55MPH (3-4 shift)
4) No 4-3 kick down above 55 MPH at WOT (Designed that way?)
[Modified by CptMorgan, 7:59 AM 12/10/2002]
To Transgo Kit Installed --> Help! 1-2 Problem
