Add Upper Control Arms?
Old Jan 17, 2021 | 11:54 PM
mayes8229's Avatar
mayes8229
Cruising
Default Add Upper Control Arms?
I need to convert an 84 to use CV half-shafts because this car is getting a Tesla rear drive unit, so I'm trying to figure out a way to incorporate upper control arms. Has anyone done this? Looking for tips on mounting locations and geometry.
My initial plan was to graft in a complete C5 or C6 rear suspension and carry the drive unit in the subframe, but I want to explore all my options. A bird in the hand is worth two in the bush, right?
Thanks,
Sam
Old Jan 18, 2021 | 10:33 AM
MatthewMiller's Avatar
MatthewMiller
I think your problem will be that a C5 rear suspension is set up for the width of a C5 halfshaft, but I would think the yokes are a different width apart on the C5 (probably wider) since it's a transaxle. The way to make that work would be the use the whole C5 rear setup as you said, but since that's a transaxle I seriously doubt you can fit it. You'd be far better off adapting the Tesla unit to work with the stock C4 halfshafts and suspension. If that's not possible, then I'd honestly suggest you stop and switch to a whole C5 platform.
Old Jan 18, 2021 | 10:42 AM
mayes8229's Avatar
mayes8229
Cruising
I wouldn't be using the transaxle if I went to the later model rear suspension. I also won't be trying to mix C4 and C5 suspension parts. It's either "out with the old and in with the new" or modify the old to use an upper control link instead of the half-shaft as a locating member. My questions right now are about the latter.
Old Jan 18, 2021 | 10:48 AM
MatthewMiller
Okay, I was replying to your remark about your original plan to "carry the drive unit in the subframe." But as for adding an upper link, there's nothing to add it to. The only possibility I can think of is to remove the body and build a whole cage/frame that you could attach the upper link to. But then you have the problem of the upper and lower arms being attached to two different frames, and the lower batwing can move around on its bushings. This means you would change geometry with different loads as you drive. So I don't see this as a good solution. Even if you replace the batwing bushings with metal bushings, the batwing would still be tied to a pretty flexible part of the main frame and could move relative to the upper arm mounts (Tom400cfi has a big thread about this flexibility). You'd really just have to do a full cage from front to rear and tie the batwing and upper arm mounts into it.
Old Jan 18, 2021 | 11:06 AM
mayes8229's Avatar
mayes8229
Cruising
Ah, I see. Yes I do have concerns about fitting it in a C5 subframe.
This thing is already fully caged, but I could even foresee modifying the batwing-frame mounts and building an upper "subframe" that hard mounts to the batwing for the control arm mounts. That subframe could be tied into the the diff cover portion of the batwing because I won't be using the diff. My main concern is having a good place to mount the arms to the knuckle. The area where the sway bar bolts in seems like the best spot to me, but I'm not sure if there's enough beef there.
Old Jan 18, 2021 | 12:59 PM
jayjones's Avatar
jayjones
How much of the rear drive unit do you have?
Old Jan 18, 2021 | 01:00 PM
mayes8229's Avatar
mayes8229
Cruising
Just the motor/inverter/diff assembly.
To Add Upper Control Arms?
