1991 Corvette Idle Speed Adjustment Procedure
Ps. I guess that the idle speed of the engine should be around 600 rpm, is this right?
1. Jump A and B on the diagnostic terminal.
2. Ignition on
3. Unplug IAC
4. Start car
5. Adjust screw until idle is near 600ish. Different specs for auto vs manual but 600 is close for both. May need to remove plug to access screw.
6. Shut down.
7. Connect IAC
8. Adjust TPS
This should be completed with the engine at operating temp. Others chime in if I missed something. Edit, maybe it should be 450 rpm? Can’t remember. It’s been a while.
The official way to do it is wonderful IF you want to make assumptions. I would, and do, forget that entire thing and check things before throwing parts at it. Are you sure that the timing is right? Make sure the harmonic balancer is not moving on you. After all these years, IF it is original, it might. If it does, your timing will probably be wrong. If that is wrong, setting the timing is difficult. TEST for good balancer. If the balancer is right and the timing is at 6 degrees, check the fuel pressure. Does it spike up to the right numbers? Does it hold pressure after shut off? If so, time to move on to other things. Plugs and wires, cap and rotor. If those are good get yourself a scanner. You will need it sooner or later. Not a code reader, a scanner where you can see live data.
With a scanner, you can see what the ECM wants the idle to be and not what we say. Drive it for a while and let it get to closed loop and operating temperature. Check what the ECM wants at this point and see what the ECM says the rpm is. Your tach could be inaccurate and IIRC, they often are. Check what the IAC counts are. IF they are higher than 30, the ECM is asking for more air. Turn the adjustment screw in to open the blades. Rev and check again after it settles down. If it is lower, turn it out to close the blades. Now if it is 0 and you can't do anything about it, you have an air leak. Once that is set to 30 counts, give or take a few, you are done. The TPS cannot be set.
