Hydraulic Fluid in 4+3
I've personally run all my 4L60E's with hydraulic fluid as it tightens up the converter, firms up the shifts as well as runs way cooler under load all great benefits if you can tune the trans to your liking. The 4+3s especially the early ones are all haunted with failure, so I was wondering if anyone has experimented with something other than ATF in them. It won't help with the bearing design faults but I think it could extend clutch lifetime and since something like AW36 is more viscous than ATF maybe bring pressures up for pumps on the way out or that have sealing problems. Any thoughts or ideas?
ive certainly noticed in the oilfield running equipment that guys will use whatever is around. i dont have the knowledge to mess with it in transmissions that have clutch packs etc.
But, as you stated, apparently it is being done. Some info to consider...
https://www.theturboforums.com/threa...of-atf.303735/
This one has a person that claims to be a pro that "forumulate various hydraulic fluids and ATFs"...
https://bobistheoilguy.com/forums/th...ission.196877/
The same pro, user "MolaKule", has some advice here...
https://bobistheoilguy.com/forums/th.../#post-1111352
Quote from a dragzine article, "Heads-up racing is a whole different world when it comes to ATF selection, and there are even racers who use hydraulic fluid inside their transmissions. Even though the transmission will still shift when using hydraulic fluid, there are some shortcomings to this — the primary being that these fluids aren’t designed to be exposed to high levels of heat and are prone to oxidation."
https://www.dragzine.com/features/lu...fluid-101-hpl/
When I search for C4 and hydraulics, I keep getting hits on Ford's "C4" trans and if it is about a C4 Corvette it is about clutch hydraulics.
I also emailed GearBoxVideo to get his opinion.
https://www.youtube.com/c/GearBoxVideo/featured
As I said before, another down side it is raises line pressure so you can blow seals if you're not careful.
The Hy-Gard is designed to be used in wet-clutch environments and wet-brake tractors and has the required friction modifiers to be able to function correctly, the 4+3 is the former of the two. He actually goes on to say...
While I do not wish to disagree with Paul, I think Hygard MAY help with all these issues except the washer issue. In the last case, the viscosity of the hydro fluid would mean that the lack of a seal would not have as big of an impact on volume lost due to the lack of a seal, which could translate into the carrier bearing being lubricated better, but I'm not familiar enough with the lubrication system of the 4+3 to know if that is the case in terms of the lubrication of the carrier bearing, it could be partially submerged, or splash lubricated or have oil fed to it.
It would definitely increase the volume the pump could move as the higher viscosity would "seal" the tolerances in the pump better than the thinner ATF, the higher volume would mean higher pressures on the clutch packs, which would decrease the heat created due to slippage and thus the holding torque of the lesser quantity of clutches in the early OD units. Personally, I have run it long enough in my truck (90k miles) to say that it is definitely the better option than ATF in the case of the 4L60 if you know how to adjust the ratios to get the desired slip in the TC. The only downside I can see is, like the 4l60, the shift into OD will be much firmer and quicker and will almost definitely require using the clutch to prevent damaging the driveline. I am gonna give it a try in my 4+3, it's going behind an LS so it may not last that long regardless, I don't want to bother Paul anymore but I may reach out and ask him about his opinions of the people running Hy-Gard or the likes in their autos.
As far as the viscosity difference with pump sealing... the difference is marginal. A 2 cSt difference is not much. (Once it shears in use who knows. Mine has been okay so far.)
This is true, but that is also the viscosity at 100C, I think if the OD's oil were to get to 100C it's not an OD anymore and just a money pit. At 40C it's a difference of just around 15cSt, which is 150% that of ATFs at the same temp. I'd estimate the OD to run at maybe 50C but again I don't know enough about these units to say. On a 250 mile trip, with around 75 of them being in the mountains my 4l60 will hover around 49 to 60C with the Hy-Gard, and I very much doubt that the 4+3 generates enough heat for it to run similar temps.
Anyway, Paul from 5speed.com says go with a Dexron oil since they aren't the cause of the issues in the 4+3 but I'm still gonna give it a shot, just because it isn't the cause doesn't mean something different won't help.
