Skipping module 9 when checking codes
Old Feb 5, 2021 | 02:48 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
Default Skipping module 9 when checking codes
It runs through modules 1 and 4 but then skips 9 and goes back to 1.
Any idea why it's skipping that section? Clearly, it's the ABS stuff, but I'm hoping it's just a fuse under the hood some place.
Old Feb 5, 2021 | 02:49 PM
Natty C's Avatar
Natty C
I jumped the two corners to check codes on the dash, btw. So A and G I think they are.
Old Feb 7, 2021 | 05:15 PM
Natty C's Avatar
Natty C
I still need to figure this out if anyone has any ideas about why it's happening.
All I can think of is cracking open the ecm and giving it a good once over.
Really hoping I don't have to dig into the ccm. Ugh...
Old Feb 7, 2021 | 05:28 PM
Natty C's Avatar
Natty C
Never mind, module 9 is only '94-'96.
'90-'91 only has modules 1 and 4. Which is what I have. To flash ABS codes, you have to short H to A and then the ABS light will flash those codes, if you have any.
'92-'93, module 7 is also displayed.
Thanks! Heh heh.
Old Feb 7, 2021 | 06:29 PM
Natty C's Avatar
Natty C
Relevant reading...
​​​​​​https://www.corvettebuyers.com/c4vettes/codes.htm
To Skipping module 9 when checking codes
