Oil Pressure Sender
Old Feb 12, 2021 | 05:46 PM
wedoo2's Avatar
wedoo2
Default Oil Pressure Sender
I have attached a couple of pictures. One being the current set up of the oil pressure sending unit on my 84. The PO installed an aftermarket gauge that bi-passes the digital dash as it was broke. In order to bring this back to original I feel like I need to remove that plumbing I have circled, and put in a new sending unit. I have attached a picture of the part that I ordered. Standard part PS155 is what I was sent.
I guess I just need reaffirmation of what I need to do. The threads on the Standard part look to be a bit big but we'll see. I have not found the connection that would go into the blade end of that part and may need to run a new wire for it. At least not yet.
Old Feb 12, 2021 | 06:12 PM
JoBy's Avatar
JoBy
That is not the correct part for 1984 Corvette. It should be 3 connectors. It is a combined oil pressure sender and oil pressure switch.
On the instrument cluster schematic you see the oil pressure sender with switch, On the other schematic you see the switch as a failsafe backup for the fuel pressure relay.
The sensor you have will probalby work for the dash.
Old Feb 12, 2021 | 06:20 PM
JoBy's Avatar
JoBy
I found my old sensor. This is what you are looking for:
Old Feb 12, 2021 | 06:33 PM
WVZR-1's Avatar
WVZR-1
Not all '84 had the three terminal sender arrangement! The OP's part is correct for the later. The later uses different nipple/elbow and switch components. Later '84 is same as '85.
The OP's pressure sender would require a GM# 25036553 or equivalent 2 terminal switch to complete the fix with appropriate wiring, elbows and fittings. It would be plumbed like this. 12 is his sender and 14 would be a 2 terminal switch. Echlin switch here in the USA would be a OP6624 or other. GM#'s for the brass is 14078987, 14078988 or of course after-market equivalents..
**Someone parting an '85 to '88 could maybe help the OP or maybe parting a late '84.
Old Feb 12, 2021 | 08:39 PM
wedoo2's Avatar
wedoo2
Ok guys I figured it out. I found the original connection and it is indeed a three pronged connector. Not sure how I missed it before but it was tucked underneath other stuff. I can be a dumbass sometimes. I'll return the part I ordered and get the right one. I take it that I will have to remove the current plumbing though?
Old Feb 12, 2021 | 09:04 PM
WVZR-1's Avatar
WVZR-1
The 3 terminal will likely be a $50 buy so if you're into what you've got for few $$$ maybe you just do some plumbing to accommodate it and buy the pressure switch which is cheap. The wiring shouldn't be an issue.
Old Feb 12, 2021 | 09:33 PM
wedoo2's Avatar
wedoo2
Yea. Looks to be a $33 piece. Nice. I love this place. I am not an auto mechanic, I've always worked on Japanese motorcycles and was pretty good at it, but this car. Oh, this car....
Old Feb 13, 2021 | 05:49 AM
JoBy's Avatar
JoBy
The thread is an 1/8 NPT and as you see on my picture, first a longer 90 degree on the block. Then a shorter 90 degree to the sesor.
On your picture it looks like both of them are still there. They just replaced the sensor with a hose fitting. Just remove that hose fitting and install the sensor.
Old Feb 13, 2021 | 05:28 PM
wedoo2's Avatar
wedoo2
Yes, that's pretty much what I figured. I ordered the part. $33 Not bad. I really get in over my head when it comes to the electrical system and I think that the C4 Corvettes can be a real challenge. There is a lot of what was new then put into the car and that allowed a pretty cool dash. If the PO had just spent the money to get the dash repaired he would have saved himself a lot of trouble bi-passing all that stuff just to install new gauges. But his effort made me learn, so that is good. Now, maybe my dash will work fully and I go on with other stuff.
To Oil Pressure Sender
