LED under dash courtesy bulbs
Old Feb 17, 2021 | 02:24 AM
1475glenave's Avatar
1475glenave
Default LED under dash courtesy bulbs
1985 corvette. I want to replace the OEM under dash courtesy bulbs 578 with LED preferably in blue. If I can’t find a blue replacement I could line the inside of the housing with blue transparent film. The oem 578 bulbs have a metal wire on each end that looks like a staple. These wires hook over a small projection on either end of the copper conductor strip in the housing. The LED replacement bulbs all have “torpedo”shaped ends with no wire to hook over the projections in the housing. They refer to these bulbs as festoon. I don’t think these bulbs will fit in the housings as it is now. I have read about guys switching out these under dash courtesy bulbs with LED bulbs. Does anyone have a suggestion other than not switching to LED?
Old Feb 17, 2021 | 05:54 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Easiest would be to (neatly) splice into the wiring so you have both the OEM socket and the LED socket.
BTW, why blue instead of matching the color/tone of the dash lights?
Old Feb 17, 2021 | 06:38 AM
Mixednuttz's Avatar
Mixednuttz
2023 Corvette of the Year Finalist - Modified
2022 C4 of the Year Winner - Modified
Finalist 2020 C4 of the Year - Modified
I replaced the foot well lights with LED in my 85 some time ago. I believe I used these https://www.superbrightleds.com/more...-44mm-car/244/. Looks like they are available in blue.
Old Feb 17, 2021 | 08:35 AM
1475glenave
hi and thanks for trying to help me out. Sorry don’t really understand how splicing into the existing wiring gives me a led socket. How will the LED bulb fit into the existing housing simply because it’s spliced into the line now. that housing is not designed for that type of an LED bulb I think. Unless I’m missing something!
I thought blue would be a nice color for the under Dash lighting because I have light blue leather seats and navy blue carpeting which I just installed plus the car color is a light blue with a darker royal blue in the bottom 1/3.
Old Feb 18, 2021 | 02:24 PM
LiveWire1's Avatar
LiveWire1
I removed the housings and soldered the pointy end LED bulbs in place. Easy job at a low cost.
Old Feb 18, 2021 | 04:39 PM
1475glenave
did you solder the pointy end to the copper metal conductor (where the bulb attaches to) inside the housing? Then use the existing housing? Thanks
Old Feb 19, 2021 | 11:46 AM
LiveWire1's Avatar
LiveWire1
Exactly. Just a drop of solder on the bulb ends to the contacts in the housing.
Old Feb 19, 2021 | 01:31 PM
1475glenave
Default Solder bulb
Thanks again I will try your technique!😎
To LED under dash courtesy bulbs
