I looking for a prom for my 1985 stock Corvette with automatic transmission. This is the HLH 3200 prom GM part number 1227805. My problem is the early lock up of the torque converter at 15 mph and I believe this upgraded prom will solve the issue. Does anyone have one that I may purchase or where I could have one made. Thanks for your time.
Brian
Brian
There are different mods you can do to control your lockup. On my 84 C4 700r4 I eliminated lockup in 2nd and 3rd gear and in 4th gear I have a toggle switch so I can choose whether to lockup in 4th gear or not. Pretty easy to do but you have to drop the pan, disconnect a few wires and install a $10 normally open 4th gear pressure switch.
all u need is an hlh3200 in an 85.
That link is the actual bin you burn to a 2732a PROM chip of course you need the equipment to do this. If you want to take peak what's on it, you can download TunerPro and the appropriate $1F.xdf to poke around.
If all you want is a chip with this BIN on it, I can burn one for you.
I can confirm that this BIN has the minimum speed for TCC lockup set to 41 MPH. However, of course without knowing what your car's current chip is, I can't guarantee that this is the actual solution to the problem you're facing, as for all I know the chip already on your car has the same setting and there's something else going on.
sounds like Nomake Wan is your guy. he can take the hlh3200 bin and put it on your original if you send it to him. or buy a blank from him and he’ll put it on.
nomake, this issue is a HUGE DEAL with 85 autos. i had an 85 auto back in 2016 while also having an 87 auto at the same time. the 85 was undrivable (compared to the 87, which behaved like any modern automatic).
chev released this updated hlh 3200 as a fix for retarded drivability issues of the feeling of stack shifting (which was early lockup, not a 7 speed trans like it felt like)
anyway, this OP is the third person ive seen come along and i always try to help because the 85 autos are absolutely atrocious to drive otherwise.
nomake, something else that 3200 did was make the 85 idle the same as the 87. not sure how.
nomake u could advertise these as an 85 fix and keep them on the shelf. people just dont know.
I can't put it on the original because I don't have a UV eraser (and don't intend to buy one). So don't bother sending me the original PROM. I do have a few 2732A chips laying around so burning one isn't a problem.
That said, I don't have a ton of them laying around, so I'm not going to go into the market of fixing everyone's '85 Corvettes. But as long as I have a few, if someone needs one, I'm more than willing to help out.
Thank you VikingTrad3r for your advice. Nomake Wan has offered to make me a prom. I hope one day I can return the help.
perfect. that chip was the final icing on the cake for my 85. i had completely cleaned and resealed the engine.....drove like a stung bull. the factory 2200 stall made that car super fast off the line. faster than my 87
Brian
Hi
Most aftermarket chips will have the update for torque converter lock up at higher rpm, i had a hypertech power chip which had that mod.
I used a toggle switch connected between the ecm plug wire going to the auto trans TCC lockup solenoid before i got the aftermarket chip.
I still have the toggle switch for track use to disable the torque converter lockup when i want, i only need to use the torque converter lock up on highway road trips to help fuel economy.
I think GM did have a recall to have the torque converter clutch lockup issue fixed to a higher speed, some had this done others missed out.
The TCC wiring comes from ECM plug terminal A7 a tan/black wire, that goes to the transmission.
Just break that wire with a toggle switch to turn it on manually when on a highway, is a simple cheap fix.
