Spark Plug Question
Old Feb 21, 2021 | 08:08 PM
Chris Draper's Avatar
Chris Draper
From: Gilbert, Arizona Currently Own: 1998 Coupe YouTube: My Corvette Life
Default Spark Plug Question
So it’s my understanding that 85-86 used cast iron heads that take tapered seat plugs, and 86-91 use aluminum heads that take reach threads with a gasket.
Ok, so I have an 88, and the plugs I removed are the ones with a gasket.
The 88 service manual shows using tapered seat plugs.
So.....which is it?
Old Feb 21, 2021 | 10:17 PM
aklim's Avatar
aklim
IDK, Both NGK and the AC Delco look up says that they use the gasket one.
Old Feb 21, 2021 | 10:43 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed my '88 uses the gasketed plugs, along with a little anti-seize on the threads.
Old Feb 21, 2021 | 11:25 PM
SloJo's Avatar
SloJo
There should be a number cast into the head. You can use this number to find out what engines it fits and the years.
Someone may have changed heads on it at some point in time.
Old Feb 22, 2021 | 12:39 AM
84 4+3's Avatar
84 4+3
Originally Posted by ihatebarkingdogs
It is not uncommon to find illustrations that are "typical" but not necessarily 100% accurate to the year of discussion. I agree that a reference to "taper seat spark plug" in a 1988 FSM is confusing.
Aluminum heads use the 3/4 reach 14mm gasketed shell. Not a taper seat.
Yeah, my 84 FSM uses some drawings of engine parts that resemble C3 components... v belts included. I feel it is a safe assumption that some things in the service manual are carried over drawing wise. The written text however should be accurate.
To Spark Plug Question
