Lets see your nitrous bottle mounted...
Old Dec 11, 2002 | 10:39 AM
No Ordinary 91's Avatar
No Ordinary 91
Cruise-In III Veteran
Default Lets see your nitrous bottle mounted...
I am expecting my kit here in the next few days, and will probably be working on doing some of the install this weekend, where did you mount the bottle, lets see some pics, I am probably going to be mounting mine in the spare tire carrier, but am not set on it at this point.
Old Dec 11, 2002 | 02:48 PM
LPDesRoche's Avatar
LPDesRoche
Default Re: Lets see your nitrous bottle mounted... (No Ordinary 91)
Do a search on this topic, there are 2 or 3 threads that are fairly recent(2-3 months ago) that have tons of pics on this subject.
I personally like the spare tire carrier as well.
Old Dec 11, 2002 | 08:34 PM
red-y's Avatar
red-y
Sorry no pictures, but there are plenty posted. Having a convertable I have moved mine, changed bottle sizes and ended up with a 10 lb bottle in the center. I can reach the valve easily and have some room (not much) on either side. I have a 5 lb bottle that gives me more room but not enough gas. I like the smaller bottle but hate to run out just when a Cobra pulls up. :smash:
Old Dec 11, 2002 | 08:37 PM
95AquaC4's Avatar
95AquaC4
Here's mine.
Old Dec 11, 2002 | 11:34 PM
marylandz's Avatar
marylandz
Default Re: Lets see your nitrous bottle mounted... (red-y)
ive seen some remote bottle openers i dont know there dependability and all but its worth a look
Old Dec 12, 2002 | 03:51 AM
zelement's Avatar
zelement
Default Re: Lets see your nitrous bottle mounted... (95AquaC4)
Aqua, cool setup! But the heater is suppose to be wrapped around the bottom of your bottle. It is important for this because the siphon tube picks up at the bottom and you want to heat up the nitrous around that tube. Plus, when your bottle is less than 1/2 empty it will not heat up the nitrous that is deposited on the bottom. That is why the bottle is tilted.
[Modified by zelement, 3:27 PM 12/12/2002]
Old Dec 12, 2002 | 11:38 AM
No Ordinary 91
Default Re: Lets see your nitrous bottle mounted... (zelement)
Not having any luck with the forum search, only found one pic of the car that says redy go on the plate with 2 in the spare tire carrier
Old Dec 12, 2002 | 04:31 PM
zelement's Avatar
zelement
Here is one for ya!
Old Dec 12, 2002 | 07:46 PM
95AquaC4's Avatar
95AquaC4
You mean further down the bottle??? My mounting bracket is in the way? :confused:
Old Dec 12, 2002 | 10:44 PM
zelement's Avatar
zelement
yeah it gotta be wrapped around the bottom of the bottle. You either have to move the bracket forward or pull the bottle down a little. This will increase your nitrous pressure a lot faster on cold days.
Old Dec 13, 2002 | 05:32 PM
95AquaC4's Avatar
95AquaC4
Okay. Will do! :cheers:
Old Dec 16, 2002 | 09:42 PM
cprgmr's Avatar
cprgmr
Well, have to chime in here! :)
Old Dec 17, 2002 | 02:15 PM
mn_vette's Avatar
mn_vette
Default Re: Lets see your nitrous bottle mounted... (cprgmr)
Here's mine, I prefer the "hidden" look :D
Old Dec 18, 2002 | 04:47 AM
zelement's Avatar
zelement
cprgmr,
Thanks for your post. I just ordered those clamps from aerospace. I have been trying to find clamps like this for years. I cannot stand the ones I have now.
THANK YOU!
Old Dec 19, 2002 | 06:02 PM
cprgmr's Avatar
cprgmr
cprgmr,
THANK YOU!
No problemo zelement - glad I could help! :cheers:
Old Dec 20, 2002 | 10:27 PM
kawboy5792's Avatar
kawboy5792
will mounting it in the spare tire carrier give you enough tilt for proper siphoning?
Old Dec 21, 2002 | 04:41 PM
zelement's Avatar
zelement
Default Re: Lets see your nitrous bottle mounted... (kawboy5792)
I don't know, that is a good question. However, I can give you many reasons not to mount the bottle in the spare tire carrier. It is too much of a pain to change bottles when you race, you also need a remote bottle opener, unless you plan on leaving the bottle on the whole time you race, if you do, that's bad for the solenoids, and bottle pressure will drop as a result. The bottle will get dirty from being outside, and the temp. will be hard to control with just a bottle heater, there are a million reason and I could go on and on. I hope those are enough reasons for you not to mount the bottle in the spare tire carrier.
To Lets see your nitrous bottle mounted...
Old Dec 22, 2002 | 04:34 PM
Caboboy's Avatar
Caboboy
Here's mine. The guage is visible and the **** is easy to access from the driver's seat :cheers:
[Modified by Caboboy, 1:35 PM 12/22/2002]
Old Dec 23, 2002 | 10:37 AM
No Ordinary 91
I was considering that, and for almost all those reasons I have decided to not mount the bottle in the spare tire carrier. I will get some pics of the install once I get started on it.
Old Dec 23, 2002 | 11:25 AM
RatRacer's Avatar
RatRacer
Not to mention that the spare tire itself is part of the DOT required anticrush protection of the fuel tank. Running without a spare is dangerous, running with a nitrous bottle in place the spare is foolish.
