Security system
Old Mar 5, 2021 | 07:50 PM
Medicmark's Avatar
Medicmark
Default Security system
I’m trying to figure out how ti disarm the security system on a 1986 C4? I already did the vats bypass and it works great but now ever time I lock the car and when I go back to open it the alarm sounds off does not mater what door I use. I tried taking the antitheft fuse out and it worked but then I lost my horn altogether. Anyone got any ideas on what to do?
Old Mar 6, 2021 | 04:20 PM
wilcar's Avatar
wilcar
Did you try to manually lock it inside and then close the door? Then unlock it using your key.
Old Mar 6, 2021 | 04:30 PM
Medicmark's Avatar
Medicmark
Ok I’ll try that right away...thanks
Old May 17, 2022 | 11:20 AM
tdking79's Avatar
tdking79
2nd Gear
Tried this procedure when my 84 vette began honking the horn continuously and would not start (I disconnected the horn to stop it until I found this procedure). It seemed to work, however it was about an hour between the time the problem happened and when I was able to find this procedure and try it. Don't know if there is a time out on the anti-theft system. Does anyone know if there is a time based reset on the anti-theft system?
Old May 17, 2022 | 03:34 PM
krafty81's Avatar
krafty81
7th Gear
Bought an 84, the old anti-theft system has caused nothing but problems. I found two fuses that I pulled off wires that go to the positive terminal of the battery. Does that disconnect the system or are there other steps?
To Security system
