To poly or not to poly???
Old Dec 11, 2002 | 03:33 PM
sraft's Avatar
sraft
Default To poly or not to poly???
The ride is pretty stable and there are no rattles/noises, so I don't think that there's significant wear with the bushings, but I'm looking for things to tinker with. In the spring, I plan on doing a brake overhaul and having the FX-3 shocks rebuilt. It would be a good time to take out the A-arms and replace the bushings.
Has anyone that's switched to poly bushings regretted it? What do you see as the pros/cons?
Old Dec 11, 2002 | 04:53 PM
John Row's Avatar
John Row
Default Re: To poly or not to poly??? (sraft)
Poly bushings made a huge difference on mine. I took the original owner for a ride and he couldn't believe it was the same car.
Pro... Biggest difference was in going around a rough corner. Before bushings, it was exciting to see where I ended up. After bushings, it was like on rails.
Con... it's been about 18 months since I had it done and squeaks are begining to come back. But it's still on rails. :D
Old Dec 11, 2002 | 05:18 PM
Feenix566's Avatar
Feenix566
Default Re: To poly or not to poly??? (John Row)
okay please pardon my ignorance...
what are bushings?
Old Dec 11, 2002 | 06:48 PM
1MoorTym's Avatar
1MoorTym
I did poly everything (front and rear) this past summer on a high mileage (read as everything worn out) car. The difference was incredible and I have no regrets whatsoever.
Old Dec 11, 2002 | 07:01 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Nothing can beat the sure feeling of Poly bushings !!!!!!!!!!!!!!!!!!!!
:smash:
Old Dec 12, 2002 | 01:26 AM
John Row's Avatar
John Row
Default Re: To poly or not to poly??? (Feenix566)
These bushings are the bearing surfaces between suspension parts. The stock ones have a rubber donut between the outer race and the inner race to cushion the body from bumps.
To see an example raise your hood and look at the front suspension. The point of the A arm is the ball joint, at the base of the A you will see the bushings.
Old Dec 12, 2002 | 08:46 AM
sraft's Avatar
sraft
Are there any lubricants (wet or dry) that provide squeak relief?
Old Dec 12, 2002 | 10:01 AM
ELEVENS's Avatar
ELEVENS
I've used them on four cars spanning about 12 years. Pros: Performace is undeniable.
CONS: 1) Noise. Every manufacturer claims they will not squeek, and every set of mine DID squeek - eventually. And I've used an awful lot of the special poly grease! If they don't squeek, then why do they spend so much effort advertising grease-grooved bushings, carbon-inpregnated bushings, and bushings with grease fittings (rhetorical question)?! The only thing I can figure is maybe the North climate and road conditions are too hard on them. CON#2) Harsh ride. I've changed back-and-forth on my 90 C4, and the poly's ride is noticably rougher over small cracks, joints, and bumps in the road. That's just me - others claim no difference in ride quality.
So, if you are going to race competitively and need the performance, go for it. The price is certainly reasonable. If you do not race, stick with the stockers.
Just one person's opinion. Please respect it and don't flame me for it!
Old Dec 12, 2002 | 11:49 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: To poly or not to poly??? (ELEVENS)
Hmmm next winter's project, this year is pretty much booked. :lol:
I know we did it on the chevelle and it made a huge difference in the handling of that. One thing I would not recommend is using the poly on the engine mounts. We did when we put in the 509 and the vibration you get off that engine throughout the car is ungodly, until you touch the gas, and then it smooth as glass. But idle, standing outside the car, you can see the sidewalls of the tires, flexing in and out and occasionally the car learches forwards and back. Looks like its having convulsions. :yesnod:
Might have to try the poly's though for the suspension. Wonder how it would help the 1/4 mile, I can see a definate advantage for road racing. :cheers:
Old Dec 12, 2002 | 12:21 PM
gh86E's Avatar
gh86E
Had all my bushings replaced about 2 years ago (~5,000 miles). Handling improved noticably. NO squeeks yet. I bought them (Energy Suspension brand) from http://www.suspension.com. Their advice was to use Marine grease - waterproof, and extra sticky. I went to a marine store and picked up a tub of this and gave it to the mechanic. Haven't had any problems so far. The sway bar bushings come (if you ask for it) with grease fittings, so you can add grease easily if they start squeeking. But I haven't heard anything yet.
Had heard cases where other brands of poly bushings don't always fit. The ES brand I got fit perfectly according to the mechanic. And once I told him about the drilling-out-the-old-bushing trick I read about here on CF, he said it turned out easy to get the old bushings out (drill a few holes in the old bushing and it will pop out much easier).
Old Dec 12, 2002 | 10:40 PM
Bluevette85's Avatar
Bluevette85
I got my bushings at www.p-s-t.com
They have kits that include the ball joints and the price can't be beat.
Buy extra grease! The little tubes that are included are not enough.
Old Dec 12, 2002 | 11:51 PM
Grzldvt's Avatar
Grzldvt
I did mine a year ago and absolutely no regrets and they are dead silent. The ride is a bit rougher, but the handling makes it worthwhile.
Old Dec 13, 2002 | 10:59 AM
silver & red CE's Avatar
silver & red CE
I poly'ed the rear bushings last winter, this winter I'm doing the fronts. The improvement in handling is quite noticable, I didn't notice any added harshness.
Eric
[Modified by silver & red CE, 10:00 AM 12/13/2002]
Old Dec 13, 2002 | 11:19 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
All good personal stories!! :cheers:
I'm feeling good about going poly! The car is still out of action so I haven't had it out to get the new "feel" yet. Man I can't wait!! :D
Old Dec 13, 2002 | 11:56 AM
SS409 425HP's Avatar
SS409 425HP
Did my '87 coupe two years ago. Installed in both front and rear. The ride is a little more harsh, but not that bad. I used the marine grease and it was ok for the first year. Now they all squeak a little at lower speeds. At highway speeds, I don't hear it.
Old Dec 13, 2002 | 05:03 PM
fullboogie
Default Re: To poly or not to poly??? (SS409 425HP)
I agree with all the advice above. The ride will absolutely be harsher, so be prepared. Energy Suspension makes a great grease that lasts forever, it seems. It's white, incredibly sticky, and comes in little tubes. Buy extra. Me, the suspension in my 96 is already harsh enough. If the bushings ever go, I'm replacing with stock rubber ones.
Old Dec 14, 2002 | 09:17 AM
gh86E's Avatar
gh86E
Default Re: To poly or not to poly??? (fullboogie)
I agree with all the advice above. The ride will absolutely be harsher, so be prepared...
I found little difference in ride quality. Now, every C4 year used different spring rates (and that's what most affects ride quality I was once told by a suspension designer), so switching to poly on my '86 may not be the same as switching to polys on an '85 or '88, and I put in new shocks at the same time (Edelbrock IAS shocks). But except for sharp-edged potholes (like where a layer of asphalt came off), my '86 is actually quite civilized and relatively smooth riding. I bought an '85 new, and while I don't have it to compare side-by-side, from what I remember of ride quality over the same area roads, I believe my 105k '86 is smoother riding than the new '85 was.
[Modified by gh86E, 9:18 AM 12/14/2002]
To To poly or not to poly???
Old Dec 14, 2002 | 10:16 AM
hngacurv's Avatar
hngacurv
Default Re: To poly or not to poly??? (gh86E)
I read in a past thread where someone said the polyurethane bushings squeek and the polygraphite ones don't. I have this on my to do list for the spring and would like to know if its true.
Old Dec 14, 2002 | 10:38 AM
h rocks's Avatar
h rocks
Absolutely harsher?? You have a '96? What else did you do to it?
The poly will tighten up your suspension. Count on the fact that the OE bushings are likely shot. If you can do all of them, do it. The diff carrier bushings were one of the single most noticeable suspension changes I made. (and I've made many) Poly bushings there tightened up the whole car. (39,000 miles) If you are really into doing the BEST bushings for the control arms, Global West are clearly in a class by themselves. Aluminum and Delrin, with Zerk fittings. Beautiful.
Old Dec 14, 2002 | 10:44 AM
sraft's Avatar
sraft
I've been looking at the posts and trying to see if there's a corrolation between an individual's mention of additional stiffness and the year of their C4. The pre-92 Z51 cars had some mighty stiff springs, and when you get rid of the rubber bushings, you're removing one of the more compliant pieces of the suspension. I'm thinking that the ride harshness on my '94 Z07 won't be too adversly affected by switching to poly bushings, just like it wasn't affected much at all (in a negative way) by the camber brace.
SR
