Monster Transmission?
1. VERY heavy it weighs 250lbs~ with fluid, you can't really pick it up by yourself, takes a hoist, I have to slide it around on a tarp
2. Four to Six additional horsepower to keep it turning ALL THE TIME. This doesn't look like anything on a dyno graph but at a constant cruise that is like 2 extra A/C compressor running... it will cost 3-5 miles per gallon extra due to rotating mass.
At 3100lbs, 3.56:1 & 27.4" Tire cruising 65-70mph is around 22mpg, average 18mpg city
there are tons of plus sides... but the bottom line is the lightweight cars are ideal kept to the 4l60e IF You can afford one from a reputable place like 700r4l60e.com
Otherwise use the 4l80e when you can't afford the 4l60e from a good place
The 4l60e might hold a mere 700hp and that is taking it easy with $5000 in parts, baby it.
Obviously the 4l80e is much stronger.
However, the vehicle application takes precedence over strength. If fuel economy or lightweight drivetrain parts are necessary then the 4l80e will never fit that app.
Naturally aspirated engines for example should NEVER use the 4l80e for 'performance'. Huge mistake.
To utilize a 4l80e proper the vehicle should have excess of 500rwhp, for starters.
Otherwise the tradeoff is hollow.
I think it comes down to preference. I would never spend money on a built 4L60e or a 700r4. I would have to spend $2K at least to get the some durability as a 4L80e transmission that I can get for under $200 at my local pick a part. That and the gear ratio's are a lot better for a street car in a 4L80. I don't understand the weight argument. If you want less weight ditch the iron block and LS swap the car. The fact is that people pound junkyard 4L80e's over and over again on the track. I have seen several "built" 4l60's and 700r4's die on the drag strip.
But you're right about lower power. I ran a 4L60e with a 400 hp motor for a long time and it held up just fine. It was just a bone stock trans that I pulled out of an 02 Camaro.
Weight is critical in general performance. e.g. 150+ extra pounds is enormous to add to any car, but especially for racing its almost a sin to add that much.
And forget about the dead weight for a minute- there is also rotating mass to consider which carries a far heavier sentence (pun intended?)
The 4l80e is a parasitic monster and it ALSO weighs a ton. I don't think GM ever made something so parasitic or heavy for a gasoline engine before.
You are right that the 4l60e is a piece of paper, flawed in many ways, complex, difficult to build properly and even more difficult to setup properly for racing.
But the one thing it has going for it, and the only reason people still use it over the 4l80e, is the weight factor.
Basically
-If you want 28mpg in a 3000lb car you can't use 4l80e, it will do 22mpg due to all the weight
-If you only have 400hp to spare, the 4l80e would gobble all that up and leave you standing still, you need a 4l60e instead
It comes down to parasitic loss, and mileage, mostly. Not so much preference... but then again mileage IS a preference? Sort of? idk
4l80e Rebuild short discussion:
As to the capability of the 4l80e unit as STOCK with high mileage. I have run these type of 4l80e successfully for years behind 500+hp
The 4l80e because of it's heavy rotating parts tends to have excess busing wear over about 100,000 miles. The bonded pistons are also said to be 'worn out' by 100,000 miles + 20 years as well (the seals get hard). There are also a couple flaws with the OEM units... the AFL valve and boost valves for example need service, the boost upgraded and the AFL reamed and a new valve used. The TCC also has a similar history of wear and leaking. the EPC solenoid from pre-02 is considered unreliable due to it's screen and weird spade style plug connector. There is some shenanigans possible with the reverse circuit in OEM transmissions where the driver slams from reverse to drive too quickly and this burns up the band and ruins reverse. Clutch wear clogs up the accumulator housings for some reason also killing reverse I've seen that. When the bushing starts to go bad in the forward drum the sealing rings on the input shaft start to cut into the drum (those teflon seals are harder than steel apparently)
Basically: I guess there is no such thing as a "good" used 4l80e with 100k+ Miles. They all need a rebuild, bushings, dual fed directs, avoid trans-go pressure mod and avoid the HD2 shift kit separator plate due to leaking historically and malfunctioning relief valve. They need AFL valve fix reamed, sonnax boost valve and sleeve. New bearings and inspect the planetaries etc... And further some lubrication mods, holes in the shafts and drums enlarged to provide addl cooling is often done in th400 and 4l80e units.
The sprags should be replaced after 100k as well, and the sprag surfaces need polishing with 1500grit. And then there is the output shaft bushing which can walk out on some units, sonnax makes a "no walk case bushing" which many will install backwards to provide 0.112" of purchase for rollerizing the rear out put shaft, another 'non critical' mod which can free up some energy and tightens up the unit. Similarly the reaction carrier needs shimmed up 0.011"~ from the center support.
Perhaps the biggest pro to the 4l80e is it's simplicity. Unlike the 4l60e, the 4l80e is remarkably easy to rebuild for beginners. Large durable parts are difficult to damage by slamming around. No tiny teflon seal & no multi vane in the pump, no difficult snap rings in the case, no special load springs for the drum, no tiny parts to fly out and get lost for the most part. Nothing annoying in the bottom of the case to deal with. The bushings are easier to install because they are larger and easier to handle. Parts being so large makes it easier to tell when something is bad during inspection.
Its like the 4l80e was made for babies. And 4l60e is a true professional's transmission... far more intricate, difficult to build, difficult to do anything with... but in the hands of a pro it can save 100+lbs of weight and a massive rotating energy cost from a car.
That said. The "real" bottom line here is a simple recommendation, since both transmission need rebuilds anyways, here is the final eschew:
< ~500rwhp use 4l60e
> ~500rwhp use 4l80e
its that simple
And you get a way better 1st gear ratio.
How way better? IIRC, I can get a rebuild on the 4L60E with a different 1st gear ratio or am I mistaken?
Just questioning for a future car when my engine fails.
For the record, I read the same about MSD optis and have 6 of them working flawlessly.
The gear ratios for the 4L80E are:
- 1: 2.482.
- 2: 1.482.
- 3: 1.00.
- 4: 0.750.
- R: 2.077
- 1: 3.059.
- 2: 1.625.
- 3: 1.00.
- 4: 0.696.
- R: 2.29
PS. I just looked at Rossler Trans. I think they have decided that the 700R4/4L60E is obsoleted beyond obsolete.
The rule above must be obeyed or the gear train locks up. The number of planets determines ratios available with a specific number of planets..
Then you need to explain how there is five planet and four planet gears for a 4L60 - both sharing a common ring and sun gear. Your explanation is true for a compound planet.
The sun gear is NOT "common" to both. The sonnax kit changes the sun gear. The ring gear remains the same.
EDIT: I just counted the sungear in the pic, it has 37 teeth, and the 4L60 gear in my stash has 34 teeth. I may have made a mistake counting either one, but the two gears for use with a different number of planetary gears is a different count.
You may have to go back and read what I said. At what point do I say that the sun gear is common to the six planet Sonnax unit and the 4-5 GM unit???? As you once said, "Words have meaning".
Removing one planetary would not cause lock-up as long as the axis of the remaining gears remain at the 72 degree spacing they are on now, with one gear 'missing'. Change the spacing to 90degrees (equal for 4 planets) and yes, it will then lock up.
Think of it this way. Imagine that instead of the planets being supported the way they are, they are each supported by an "arm" that is attached at the centre of the sun gear. Are you suggesting that arm would not be able to be moved one way or the other around the ring gear, each planet rotating on it's own independant axle, meshing with the ring and the sun? I told you before, your theory is correct for compound planets(two diameters on the same axle). They have to be "timed". I think if you reconsider this for a moment, the logic will prevail.
The center of each following planetary gear can only be placed in positions that allow both ring and sun gear to engage.
I totally agree.
But why should the carrier be forced to use 'even spacing' between gears? Having planetary gears a fraction offset to engage closest tooth is not a problem.
This is condition 1.
Condition 2 has two options.
2.3 for even spacing
2.4 for uneven spacing
