Another C4 LS Swap
In other news, the 10* throttle body adapter is now available on Thingiverse for anyone who wants it. both the STL and STEP are there.
https://www.thingiverse.com/thing:4833702
EDIT:
Rather than just say it was a bad scan, here's a snapshot of a super low res scan without the targets, this was comprised of about 270,000 points
And this abomination was comprised of about 2000000 points, almost 8 times that of the low res scan.
You can see that details like the headlights are wayyy clearer(and that the headlight is very crooked
), but everything else is gone, which is what everyone is very confused about. Our going theory is that the glass confused the software with reflections and it placed points in the air, so I will try again with the hood propped up on the grass and some settings tweaks. If you look at the driver's side of the windshield there is a red smear, there's nothing red inside the car, which is where we got the idea of the reflections being the problem. Not sure why the low res scan didn't have any problems with the glass, but that's a rabbit hole.
I think I'll be able to have a good result by this weekend and maybe even a CAD model by Sunday night, it's gonna be a wet weekend here so no installing the engine for me.
Here's the crowd participation part of the hood recreation, I did some cleaning up and did some aggressive smoothing to the last result I shared. It turned out better than I expected, but definitely not close enough to accurately model in CAD. Pictures below, and questions below them. Ignore the bumps, they were small rolls of colorful tape that I was hoping would work as targets, didn't work all that well and they caused a raised surface that doesn't smooth away all that well.
It seems the fender flares came out accurate cowl seems to have been overly smoothed into the hood and the height diminished, does anyone else get that feeling looking at the pictures? Does anyone see something that is glaringly incorrect in the shape of the hood?
If not, Friday morning I have some help coming over to help me remove the hood, and then I'll be propping it up on some sawhorses and getting as high a resolution scan as I can. Part of this plan involves having the neighborhood kids doodle all over my hood to generate "unique" patterns for the software to pick up on, the hood needs to be sanded and reprimed anyways since it's been exposed to water. From then, I'll be turning my computer into a small space heater for what I expect will be all of Friday while I'm at work and most of Saturday to create the mesh, and Sunday night I'll be sitting down for a loooonnnnggg CAD session of what will hopefully be a close to final product. Sunday morning I'm going to the salvage yard because they got 2 84s in last week, hoping to pick up a cluster, steering column, and headlight motor, since those are either broken or worn out on my vette.
https://sketchfab.com/3d-models/chev...6df1c1f2fac7ad
Looking at yours, the cowl and the hood surface are much more pronounced, where the scan has a gradual curve and blended edge. That's something I'll need to figure out how to capture better.
Also, turns out I didn't have the camera set to as high a resolution as it could go, the next shot should hopefully capture some more detail.
That looks pretty darn good, how did you model that?
I'm allegedly using the truck accessories, they fit during the mockup stage but I still need to check hood clearance to see if I'll need to cowl that far to make them fit.
I initially planned on not having AC and just driving fast, but on my daily commute to work the last couple of weeks, I tried it, and failed miserably, so AC is the current hurdle to figure out. I'm starting to lean towards using the R4 compressor and either an eBay high mount bracket or designing a C4-friendly bracket, the LS compressor would have been great, but it's too costly to make work. At least this way the plumbing all stays the same and it's as bolt-on as it can be with an engine swap of this magnitude.
With great power come even better brakes, my vettes
has terrible brakes that just wouldn't cut it in VA traffic. The first time I took it on a high way I nearly rear ended a minivan with me standing on the pedal slowing down from 45. So I've gone about fixing it a couple of ways, the cars getting new rotors and pads on all 4 corners, the fronts get drilled and slotted rotors with ceramic pads, the rears get the same rotor treatment but with semi-metalics to increase rear bias a bit, I'm personally not a fan of drilled rotors, but these have a no questions asked lifetime warranty so cheap rotors for life even if they crack the rotors. Second thing is full brake flush, the fluid in the master does not look healthy, I’m surprised the pedal hasn't gone spongy yet. I'm going at it rather aggressively and draining the system completely, so while the master is somewhat empty, I'm also putting in a DRM bias spring to make those semi-metalics actually worth something. Odds are high I'll be taking the plastic booster off and inspecting it for cracks at the same time, it would explain the stiff pedal but I have no point of reference for how stiff the pedal is on a normal 85. Lastly, the cars getting C5 calipers up front, I do plan on tracking this car a couple of times a year, and it was cheaper in the long run than the J55 upgrade. The C5 has a way better aftermarket and selection of pads and rotors and that brought the price way down for good quality parts.
The power bump I mentioned is courtesy of a TBSS intake, which outflows and has better top end than the LS6 intake while sporting a supposed 15lb/ft torque gain from the truck intake, which is why it's touted as the best factory LS intake. The power bump is nice but this intake looks better and is about an inch shorter than the NBS truck intake I was going to use. That means a smaller cowl that better blends in with the C4s lines and curves.
Don't think I've mentioned it yet, but the car will be painted black and I'm trying to place subtle yellow highlights throughout the car to match the interior. The interior is black for the most part with yellow seats, im still trying to decide how much yellow I want to have.
Fun fact: The calipers went through three different shades of yellow and being baked before I settled down on this one. Yellow is a tricky color to match.
As far as the intake goes having to redo the cowl on the hood is a lot of work, and by the time you buy all the materials to reglass and repaint etc the cost is going to add up too... I'd say your better off getting a car intake. I watched Ebay for a few months and found a older ported fast 90 intake for $500 shipped. If your patient I think you could find a similar deal. Just my 2 cents.
