My 90
Old Mar 12, 2021 | 12:06 AM
Kenneth Wyllie's Avatar
Kenneth Wyllie
6th Gear
Default My 90
So I have a 1990 vett an i need a motor transmission combo or do I rebuild wut I got. An budget is a issue
Old Mar 12, 2021 | 12:27 AM
Yguy's Avatar
Yguy
If budget is an issue, that’s normal.
For what my opinion is worth, try to find a direct replacement for each and be done.
There a a number of ways to go about it, but I’d suggest a good reputable exchange on the engine. If you’re not comfortable with that or if you prefer to keep the drivetrain original to the car, find a local rebuilder to freshen it the engine. You’ll save a good bit of money pulling the engine yourself.
As for the transmission, I don’t know if it’s manual or automatic, but if it’s automatic, again, you’ll save money pulling it out yourself. But sometimes the warranty on them can be worth having them do it.
I hope this helps. Best of luck on the project.
Old Mar 12, 2021 | 03:38 AM
Kenneth Wyllie
6th Gear
Trans I juz paid our local mechanic 2750 an he....didn't do wut I paid him 1st trans wuz supposed to get rebuilt instead he swapped it an didn't last a month...took it back he had it another 4 months then juz got yet another n tossed it in...that 1 lasted less than a hr b4 it started slipping. So no numbers matching that's y I asked him to rebuild the 1st 1 lol but yes it helped very much thank you
Old Mar 12, 2021 | 03:42 AM
Kenneth Wyllie
6th Gear
Default Where to look...
Is there a particular place to look for a reasonably priced combo?
Old Mar 13, 2021 | 12:03 PM
Yguy's Avatar
Yguy
I’m not sure how far you are from Reno/Sparks, but you can probably get a good engine/trans combo at Summit. But remember, DO YOUR RESEARCH WITH DILLIGENCE.
Get an engine with specs close to the OEM so the ECM can figure it out. Speak with the engine company directly to discuss your needs and concerns.
You can pm me if you want, or we can keep it going here.
Old Mar 13, 2021 | 02:24 PM
Kenneth Wyllie
6th Gear
At this moment my c4 is sitting on all 4 jack stands. I'm still livid at our local mechanic. I'm sending him a demand letter I would love to pic ur brain. On FB I'm Kenneth wyllie there's a pic of my car for my profile. Hope to hear from you soon an thank you
Old Mar 14, 2021 | 09:06 AM
C409's Avatar
C409
..... Wate wut ?!? .....
Old Mar 19, 2021 | 08:16 PM
Yguy's Avatar
Yguy
How’s the research going?
I’m not sure if you know a lot about Vettes, but in your engine search be sure to look for a couple things.
1) Make sure your new engine has NON-Vortec heads. And the heads your engine has should be for the proper bolt pattern of your intakes base. That, thankfully, should be pretty easy.
2) You’ll also want an engine with a 1-piece rear main seal. It’ll match up to your stock transmission with a bunch of mix-n-match parts.
as for the transmission, you’re probably going to have to drag the guy thru court for satisfaction. But that may be throwing good money after bad.
anyway, to stay stock, there may be an exchange you can do over at Summit. I believe they carry stock replacement/service parts as well as performance stuff.
I hope this helps.
To My 90
