Antenna pull question.
Old Mar 14, 2021 | 10:23 AM
93QuasarBlue's Avatar
93QuasarBlue
Default Antenna pull question.
I noticed you can get new grommets for the antenna. If I cut the rubber grommet will the unit come out so I can remove the nut when the antenna unit dropped outside? or is there a flange in there to make that impossible. I figure it would be easier to reinstall the nut from the top if I end up putting a new unit back in. Or if someone has a socket to lend me that would be great.
