need some help on a stubborn 90 mn6
I had extreme throttle body shaft bushing wear and i just finished rebushing the shaft to as new tightness so that vac leak is gone.
I am now able to get the IAC to 35 (tunerpro rt) and it will hold the target idle of 700. Perfect.
the problem is once we enter closed loop, ....when i goose the throttle a couple times its like it suddenly initiates a vac leak and i cant stop it. the IAC closes to 0 to try to bring it down, but i end up at 1300rpm. when this occurs, the o2 starts reading 800mv rich steady, and blms are 148.
fuel pressure is about 45. of note is that it is an adjustable type. i havnt messed with it because fuel pressure seems fine. injectors are good, all ohm16 hot and cold, all were cleaned and reinstalled when i did the plenum.
tomorrow i will try to clamp off every vac line to rule them and things like charcoal cannisters and vacuum accumulators solenoids out.
ive pulled the plenum apart and reassembled with good sealent on the gaskets. its not that. i tried propane, and carb cleaner. when the plenum was off, i pulled the egr and tested it, its fine.
i cannot hear a vac leak, which you would think i should be able to hear the his.
the ecu was fubar. rusty. the prom is a custom from zimmerman. it was corroded too. i cleaned it up, and put in a 1227730 ecu and the vehicle is acting the exact same.
rebushing the tb corrected the inability to set the idle, but there is something very strange going on that sends the idle very high and its been doing this since the day i bought it. none if the work ive done has affected this high idle condition.
also note: when i let the car idle with the electronic spark advance disconnected (so running on base idle) it will not runaway up to 1300rpm. maybe that isolates it to closed loop?
if u can help brainstorm id appreciate the help.
its clear there is a mammoth vac leak.
With the throttle blade fully closed, iac commanded to position zero, she idles about 650
is it possible to have an intake manifold gasket that leaks air into the system?
anybody else had any big but hard to find vac leaks?
There's guys on youtube that show how to build it DIY cheap or buy one. Scotty has an old vid where he spent $100 and it works.
Perhaps the EGR valve on top of the intake is letting air in.
fwiw I've disconnected the EGR solenoid vac line, I removed it actually, and disconnected the cannister vac line, well the hard line cracked same thing, didn't even bother to plug it or anything, and engine still runs fine.
rebushed the tb
drenched the intake manifold base with water to see if there is slurping....nope
i have a cigar.....i could do the smoke test.....but im not going to find it that way. its not a typical vac leak.
some more info:
there is a major correlation between heat and this vac leak.
furthermore, when i command the iac closed by shorting a+b, then pulling power to keep it there.....im getting air going through the iac channel still. when i plug the iac passage way it with a rag i can lower the idle but it still will not die.
when i put a piece of a vinyl binder over the intake it will die.
if feels to me like the issue is the tb itself but i cant figure out what.
is it possible to have a gigantic leak in the intake manifold base?
internally?
What about your PCV hoses and valve? Is there a hole or large crack in any of the hose / valve / fittings that could open up under heat load? I know you wrote that you've plugged up every port in an attempt to find the leak so I'm just spit-balling here....Maybe a gasket failure in the throttle body plate up top or below on the IAC housing that opens up under heat expansion?
You (and probably others before you) have done a lot of work on this engine. O2 sensors are susceptible to silicon contamination. It doesn't take much to mess them up. If you've changed the O2, then this is all conjecture. Complete WAG: Disconnect the O2 sensor and give it a go. It should set Code 13, and BLM should default to 128. See what happens to idle speed and IAC when you "blip it" with O2 disconnected.
dogs, ive never heard that there is more than one pintle shape! that would explain alot actually. i found what you said mentioned here as well. I have 3 IAC’s here all from early Tpi’s and i will see if there is ang pintle shape difference among the three and take them into the local parts store and compare to one that comes up for a 90 L98.
https://www.corvetteforum.com/forums...post1601917045
Maybe u guys have comments about this: I put playdough in the v shaped notches of the tb plates. It killed the engine. So there is enough air getting around the outside of the tb plates at the hinges that the car can run with the IAC closed, and the tb plates fully retracted. (there is a gap between the tb plate adjustmment screw and the levers foot.
In order to start the engine like this, i do have to open the tb plates a tad to get it started. But once the engine is warmed up a tad, it will run at about 650 rpm. wth?? Shouldnt the engine be starving for air like this? If i let the engine get nice and warm, the engine will idle at 1300 like this!!!!
Obviously there is something significantly wrong with the amount of air sneaking past the outside of tbs through the V notches.
when i used some of the kids play dough in the notches, it killed the engine. There is no visible play in the hinge bushing. (after i rebushed it).
pics:
u can see some residual playdough that got sucked in there. in there. i did remove that with a pic and a vacuum.
here is a bbk 52, i was planning on using this TB but the cable linkage is different. this is from an early tpi. mine is a 90. I have this up for trade to a late tpi bbk but at this point im ready to grind off the linkage retaining peens and take the late tpi throttle body linkage and put it on this.
edit: i think the iac passageway is different on these early tbs too.
I like what Dogs pointed out about the IAC pintle shape, which also reminds me that the pintle seat itself sometimes gets gunked up with carbon deposits. But you're on top of everything else so I didn't think that was a probable cause. Nonetheless, it's a good idea to check the pintle shape / seat match....
In fact im going to re-do the test, and ill put playdough in the iac passageway. If the idle comes down then id say its likely a matter if the iac not seating properly.
Do we know ...if a fully seated IAC should allow zero air past it?
edit, i can also verify that the iac and the bore/seat is clean as a whistle. Did that along time ago.
too much modification and i become a bubba. i would just find a new tb.
Just a thought; when you re-bushed the TB axle you applied a lightweight oil into the bushing areas, working the axle back and forth to pull the oil in right? Still scratching my head trying ideas on the false air intake source....
the more i think about it, there is simply no way that the throttle body bushings are causing a massive leak. they are TIGHT after i rebushed it.
Question, anyone know how the IAC pintle extension works? Does the stepper motor simply keep turning the gear and the pintle eventually meets resistance when it hits the cone shaped bore? or is it an actual “count” or voltage that the motor extends to?
Im wondering if the exu commands the IAC closed, its shows me on tunerpro that its commanding 0 counts.....how do i know if the pintle is firmly pressed into the cone shaped bore? what if 0 counts is actually not fully closed?
anyone know how to test this? looking in the fsm now.
maybe this car had a slightly bigger sized pintle from the factory?
But i took the iac passageway from the bbk and installed on the one that *looks* like the factory unit and problem solved. the iac can now make a good seal (for the record, its not a perfect seal, vacuum will build and accumulate if you put playdough into the iac channel. it does get sucked in.
But that bore was just a hair too big, and air was sucking past the pintle, even at “0” counts on the IAC. which meant i could not get control over the idle.
This felt like i was chasing a damned ghost. glad this one is behind me.
for those of you with play in your tb, its probably not a huge issue. mine was obviously this weirdly oversized bore. i probably didnt have to re-bush my throttle body.
thnx for the brainstorm everyone.
The lower pic has had the IAC housing bolts swapped out from OEM Torx head to the Allen head style, so that's a pretty good clue also that the housing may have been swapped previously...
Props to you for finally figuring it out. They're not easy sometimes, especially since if not the original owner we don't know what was done to the car beforehand.
Cheers,
AJ
dogs, do u have any part numbers or references here? i think this tb had a different iac pintle shape. the orifice doesn’t look like anyone ir anything increased its diameter. looks like it was built this way
